Home > Maintenance & Mods (L322) > Bi-Xenon shutter flicker and levelling questions
Croker
Spain
Hi, My car had Xenon without the servo motors inside. I am changing to LHD units as I am importing the car to Spain and just the lever method is not accepted. So, I got a unit from the breakers..with the motor inside. When turned on, it doesnt do a self check which I thought it would as I assumed its self leveling. It seemed to be very low and I have to get the adjusters on almost max to get the height correct. Also when I turn on high beams, the shutter works and reveals the full beam from the xenon bulb, BUT,,,,, when the engine is running, the shutter starts to flicker and drop lower in the beam pattern. If the engine isnt running, it doesnt flicker.
I only have one fitted at the moment and have the original unit on the other side connected which works albeit it doesnt have the motor inside it.
Is this a fault or a consequence of not having both fitted the same?
Should these do the self check movement when turning on as my old BMW xenons used to do?
I will post a link to a video if possible...
Any help much appreciated.
2007 Vogue.
Post #591149 13th Apr 2021 11:25pm
Croker
Spain
This shows the issue...
Post #591150 13th Apr 2021 11:33pm
Croker
Spain
Headlamp Leveling - Dynamic Headlamp leveling [064BR] According to my VIN
Post #591151 13th Apr 2021 11:40pm
wrong sort of replacement headlights ?
fit original lights and see if that all works ok. ... - .- -.
Post #591169 14th Apr 2021 8:24am
dingg1
Have you tried getting it passed by just using the lever?
Worked for me in Portugal and they are very particular about the matriculation here
Post #591172 14th Apr 2021 8:51am
he does mention that the lever method isnt acceptable in spain,,, Wink ... - .- -.
Post #591175 14th Apr 2021 9:08am
dingg1
Yes I did read that, my question was has he tried it?
Rolling Eyes
Post #591178 14th Apr 2021 9:13am
Croker
Spain
I got the adjustments sorted as one connector of the adjusters had popped out of the socket. I changed over the ignitor and Xenon power pack and the issue continued. I am waiting for the second unit to plug in and try so it has both the same type fitted (i.e with the motors) to see if its not liking just one.
Post #591283 15th Apr 2021 10:52am
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Not sure if it’s too late now, but I had an “engineer” open the units up and convert them to LHD spec. Saved ££’s on new or used headlights. Not sure how you’d find a local person able to do it. But it’s certainly doable! 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #591337 15th Apr 2021 6:43pm
dingg1
Just take off the stickers on the casing, drop the lever, the machine that checks the beam pattern will pass the flattened beam pattern Whistle
Post #591343 15th Apr 2021 7:18pm
TDV8_Tommy
“Flattening” the beam didn’t work for my ITV, the beam has to be “thrown” properly.
Wow...I’ve just realised how boring I’ve become. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #591346 15th Apr 2021 7:27pm
dingg1
Maybe the Spanish are a bit tighter than the Portuguese then Confused
Post #591352 15th Apr 2021 7:50pm
Croker
Spain
So today i replaced the units with standar LHD Bi-Xenon, no self levelling or directional, just as the original one were. Both of these are doing the shutter flicker and it only does it with the engine running. What can this be?
Post #591371 15th Apr 2021 11:20pm
Croker
Spain
I asked to day and it was a flat no! They have to be illuminating the verge too.
Post #591372 15th Apr 2021 11:22pm
dingg1
You don't ask, you say yes they have been changed to lhd and try the test, it would have passed
Well it did for me in Portugal, all cars with led headlights pass too.
Good luck
Post #591385 16th Apr 2021 8:24am
