Home > Technical (L322) > heated steering wheel: will a later type fit the 2005 Model? |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1182 |
Not quite 100% positive, but when looking for bits for my steering wheel, it looked like the same wheel will fit cars from 2002 to around 2010 / 2011.
12th Apr 2021 7:48pm |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 163 |
Thanks Merchy! Will check PowerfullUK |
12th Apr 2021 8:13pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
The wheel you tend to buy is just the leather rim with spokes and the hub. It’s bare, so you transfer your wiring pretty much. I put a later wheel on to my 2003 car when I had it, and had to keep the original module so the connector fitted. I think it had a bit of wiring with it, thinking on.
12th Apr 2021 8:43pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
Just make sure it's actually the steering wheel heating element that's at fault before you replace it. Mine wasn't working and I recently fixed it by replacing the relay which provides power to it. |
12th Apr 2021 9:24pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Steering wheels from 02-13 are all the same fitment sir... |
12th Apr 2021 10:30pm |
Hi all! Thanks for your help! Been in the car today en checked the heating element: when straight connected to an external battery no heat at all. Double checked with an ammeter: no resistance whatsoever. Beside that the heating element (when sort of working long ago...) heated over on some spots and did barely nothing on others. So it was on the way out then I guess
13th Apr 2021 4:22pm |
You can check the resistance of the heating element with a multimeter, powerful UK have a video on YouTube on how to.
13th Apr 2021 4:44pm |
Hello Kezbo, very informing video! Didn't check the thermister but did check the resistance on the heating element and that was definitely dead So a new steering wheel is due. When your spare is okay and willing to sell, than please PM me. |
13th Apr 2021 7:42pm |
