Home > Technical (L322) > right hand brake light
Bazzashadow
i have a 2012 4.4 vogue se and the righthand brake light has stopped working.
i was just going to order a new one and thought before i do fork out i better do some checks.
first i removed the light assembly and found what was earth, i then made every terminal live one at a time and all the lights worked, indicator, fog, tail and brake.
i then checked the feed from the loom and there is no live(purple/yellow cable) coming into the light with the brake pedal pressed.
has anyone else had this problem
thanks
Post #578239 3rd Jan 2021 1:05pm
Kplomson
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Fuji White
Hi there - just checking if this was ever resolved? thanks
Post #590839 11th Apr 2021 8:04am
Bazzashadow
Hi after not getting any replies and being without a car for a month and half I took it to an auto electronics and apparently it was the tow bar electrics shorting to earth and spiked the bcm.
Bypassing the bcm and all working now
Post #590921 11th Apr 2021 8:27pm
Kplomson
Thanks for the update - very grateful. Did you change the BCM or just bypassed the the tow bar electrics? Thanks
Post #590925 11th Apr 2021 8:51pm
Bazzashadow
I don’t know
But the said they have bypassed the bcm
My bcm is in the fuse box in the dash and not under the passenger seat overwise I would of changed the bcm
Post #590964 12th Apr 2021 6:25am
