Home > Maintenance & Mods (L405) > Range Rover hood letters
funnyguy1
United States
I am replacing the RR letters on my hood and ordered a set from Great Britain. They arrived today in templates but the spacing is narrower by about 1/2". Are the letters spaced differently for different RR's like the Evoque?
Post #590639 8th Apr 2021 12:40am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Cut the template between each letter, and then put the template pieces over the existing letters on the bonnet then tape together - hey presto, perfect spacing. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #590644 8th Apr 2021 6:53am
funnyguy1
United States
Thanks Z! I'll give it a try.
Post #590659 8th Apr 2021 2:08pm
evoques are smaller in size so it possible you have a set for that vehicle.. ... - .- -.
Post #590662 8th Apr 2021 2:39pm
funnyguy1
United States
Hi Stan, The letters are the same size but the spacing is closer. Is that what you mean?
Trying to see if I can cut and reposition template. Thanks Mike
Post #590664 8th Apr 2021 2:48pm
mjdronfield
Are you sure the ones already on are correct?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #590665 8th Apr 2021 2:56pm
funnyguy1
United States
Yes they appear to be correct. As I mentioned, the dealer installed the letters over the new 3M clear bra but installed them about 3/4" off center. I also checked with my wife's 2014 and they are also correct. Just have to cut template as D suggested and see if I can get them straight. Dealer said they would redo if I brought down but its a 3 hour drive. Mike
Post #590666 8th Apr 2021 3:00pm
Flyingfocrs
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
I’ve done this twice now with the same result, my rear template was embossed “sport”
Supplier just said they only did one template for all models.
I used 3m detailing tape to mark where the letters were before i removed the old ones.
Post #590690 8th Apr 2021 11:26pm
funnyguy1
United States
Letters came out great! Cut template and then took measurements of all letters from the hood of my wife's bonnet. Thank you all again for your help!
Post #590721 9th Apr 2021 3:13pm
