Home > Technical (L322) > Td6 gearbox refitting |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Sounds like the TC has not located on it's fitting and is pushing against the flex plate, there is a tool to hold it engaged while you fit the box, the movement of fitting the box can make the TC come off it's seating and cause your symptoms, I afraid it's a box out again job to sort it... Pete
6th Apr 2021 5:42pm |
mark g Member Since: 28 Dec 2015 Location: Shropshire Posts: 31 |
We checked that . We left the box in park when we took it out. Have put it in neutral but makes no difference. |
6th Apr 2021 6:47pm |
Don't know what to suggest then, a TC not seated is a common issue and the flex plate should be spinable by hand, it shouldn't need anything else.... Pete
6th Apr 2021 7:02pm |
Thanks pete. We have had the box out once already as the tc was not engaged correctly as you said. Looks like it may have disengaged again and you are probably right. Thanks for your replies pete very grateful for help |
6th Apr 2021 7:12pm |
Could it be possible that we have fitted the flywheel the wrong way round? It seems further back towards the engine block than it was |
7th Apr 2021 5:37am |
Never done the job on that engine, I suppose it's possible, there should be witness marks on the bolts that hold it and the TC on, I would have thought it would be pretty obvious but you never know...
7th Apr 2021 9:36am |
Turns out we were both right pete. The flywheel was the wrong way round and when i put a flex plate bolt in . It pulled the tc off the shaft and locked it up many thanks for your help |
7th Apr 2021 3:42pm |
No bother, glad it's sorted... Pete
7th Apr 2021 4:05pm |
