Home > In Car Electronics (L405) > 2019 Vogue Apple Car play not working
Bg259
Just bought a 2019 Vogue and the Apple car play will not work.
I have tried 4 cables, genuine Apple cables, 3 different iPhones, and an old iPhone 7 just to make sure.
An android iPad.
Resetting the Bluetooth.
Still no go. The system says Connection failed. Disconnect the USB and try again.
No joy. Anyone have any ideas ?
Post #590175 4th Apr 2021 1:45am
tomo141
I have MY18 and apple car play only works with the USB under the arm rest. ------------------------------------------
L460 D350 73 FFRR Autobiography Santorini Black with Shadow Pack
L405 4.4 V8 18 FFRR Autobiography (facelift) Santorini Black with Shadow Pack
L405 3.0 V6 13.5 FFRR Autobiography Santorini Black
L322 4.4 V8 12 FFRR Autobiography Santorini Black (RR Styling Pack)
L322 3.6 V8 10 FFRR Autobiography Santorini Black
L322 3.6 V8 07 FFRR Vogue SE Santorini Black
L322 3.0 I6 55 FFRR Autobiography Santorini Black
Post #590202 4th Apr 2021 10:28am
Chalky
BG259, have you checked whether an update is available? Settings/ Connectivity/ update.? You should have SOTA so you can download an update if there is one available. Also check another device with the USB, it could be the port at fault. Failing that, then I'd give the dealer a call. All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #590212 4th Apr 2021 11:25am
Bg259
I have tried 3 different phones and an android phone.
I have tried the USB under the armrest. The 2 next to each other.
Might need to call the dealer.
SW is 20C
Last update Feb 21.
Post #590218 4th Apr 2021 12:05pm
Bg259
Chalky I noticed on your signature you have ordered a D300 mheV. I was going to buy that car. Was getting a great deal. Decided on a 19plate as I was being impatient !
Post #590231 4th Apr 2021 1:42pm
Chalky
Yes, I bought that engine because it is a step up from the last 3.0l in my 2018 car. I found the 3.0l was perfect for all that I need to do, no towing etc.
I was going to wait until the new model comes out later this year (?) but because of the software problems I had with the facelift car I thought I’d wait a couple of years for the teething problems to get sorted!! The software only got sorted when they installed a new 2020 unit in the car so if I were you I’d get the dealer onto your problem straightaway! All LR cars from 1984
Post #590233 4th Apr 2021 2:10pm
Bg259
What problems were you experiencing Chalky?
That’s also the reason I didn’t get the D300. Thought I would order a new L460 early next year.
Post #590237 4th Apr 2021 2:31pm
Chalky
All sorts of problems from blank screens, no sat Nav, no radio, no ACP just a nightmare.
I got onto LR HQ and made a stink and eventually because the dealers couldn’t sort it, it was decided to put a completely new system in which was a 2020 edition. Since then it hasn’t missed a beat. Your car is still well in warranty so I’d go back to your dealer and get them to sort it out for you. All the dealers know there are known problems, it could be just an update. All LR cars from 1984
Post #590238 4th Apr 2021 2:41pm
Bg259
My left steering wheel button seems to act slowly/not match what I’m pressing sometimes. The rest seems to work. When I plugged in my daughters android iPad. It came up on her Amazon fire, very low charging or words to that effect.
Not sure if there is a usb problem.
Post #590239 4th Apr 2021 2:44pm
Chalky
Might be USB and I had the same slow left hand menu button too. I’d definitely call your dealer and let them deal with it👍 All LR cars from 1984
Post #590240 4th Apr 2021 2:47pm
Bg259
My local dealer has booked a “triage” appointment by phone next week. Not sure what they can fix on the phone?!?
Post #590264 4th Apr 2021 7:58pm
Chalky
They'll be taking advice from their people in Solihull. That's what they did with mine and how I ended up getting a new unit installed. All LR cars from 1984
Post #590292 5th Apr 2021 8:46am
Bg259
Chalky will let you know the outcome once they have diagnosed.
Did you go for a black pack Westminster? What options did you specify on the car?
Post #590295 5th Apr 2021 11:03am
Chalky
Hope all turns out ok which I'm sure it will!
I've bought a D300 SE in Carpathian (had BRG before but damned if I'm going to spend another £5k just for colour again!!)with Pixel lights, Ivory leather, no Privacy, Shadow walnut finishers, HUD, mudflaps and rubber mats and the rest is standard spec for the SE. I thought about an Autobiography this time, but I don't use all the bits on an SE so because the Auto doesn't have HUD as standard I thought the SE was perfectly good for what I need. Being a Shootin'/Fishin' man it has all I need for going off road too.
I also have from my last car, a Hatchbag bootliner and a Boot Buggy poly clear dog guard which are brilliant and I would highly recommend, plus a K9 dog box for when the dog is in the car.
All good Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up All LR cars from 1984
Post #590298 5th Apr 2021 11:24am
