![]() | Home > Maintenance & Mods (L322) > Too Much Oil - 4.4 TDV8 |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Does the display say it's overfilled or are you just seeing the level is close to the top of the gauge? 2011 TDV8 Vogue SE |
This thread may help too
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 ![]() ![]() ![]() |
It says it is quite a way beyond the maximum indicator. |
That looks interesting. Thanks. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
8.5L at oil change NOT what the manual says Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Suck it out via the vacuum pipe on top of engine. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 294 ![]() ![]() ![]() |
DO NOT try and remove the sump bolt and then put it back in. You will end up with about 9 litres of oil all over the place. Ask me how I know.
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Also be aware that the gauge is very sensitive to gradients. the car must be on an absolutely flat and level surface or the gauge to read correctly. Even a small incline can have a significant impact on what the gauge says. Bish.
