Home > Maintenance & Mods (L322) > Rear subframe bushes replacement cost |
V8Simon Member Since: 18 Dec 2019 Location: North Wales Posts: 20 |
Just had the call from the garage to say mine are goosed and given them the go ahead to do it. Don't have a cost but will check back with them and see what they think. Not a LR garage btw
30th Mar 2021 1:35pm |
Sleepy Jen Member Since: 15 Feb 2021 Location: Basingstoke Posts: 32 |
Mine are on the MOT advisories from last year, I have read that they can be changed on the car with a bush removal/fit tool for a BMW X5 - does anyone know if this is true??? |
30th Mar 2021 7:23pm |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 |
https://www.fullfatrr.com/forum/topic21092...r+subframe
30th Mar 2021 7:57pm |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
I supplied them and a local garage charged £160 to fit them. 2010 VSE [Roger] |
30th Mar 2021 9:49pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
Yes the X5 subframe Bush Tool kit works as that's what I used on mine, e.g. Sealey VSE5585. The advantage of the bush tool kit is you don't have to drop the subframe a massive amount from the body to extract or install the bushes. The subframe can be dropped using the damper lower attachment bolts in place of the subframe bolts as they are longer, with 2 bolts in opposing corners and the remaining removed it allows enough drop to use the tool. If you don't want to remove the damper bolts they are part number RYP000110/RYP000111. It's the way it's done in the workshop manual and makes it pretty easy: https://workshop-manuals.com/landrover/l32..._subframe/ |
31st Mar 2021 7:19pm |
Thanks Weejock. |
1st Apr 2021 10:03am |
