Home > Maintenance & Mods (L322) > Rear subframe bushes replacement cost
HS66
This isn’t one I want to tackle myself as I don’t have a ramp or the software to stop the air suspension carrying in trying to inflate the airbags, plus it just looks like an all round pain to do, does £650 from a garage sound about right?.
Post #571026 26th Oct 2020 7:56pm
V8Simon
United Kingdom 2004 Range Rover Vogue SE Td6 Java Black
Just had the call from the garage to say mine are goosed and given them the go ahead to do it. Don't have a cost but will check back with them and see what they think. Not a LR garage btw
Paid £360+VAT (20%) labour for them to change the bushes. Bushes (parts) were £58 each and there's 4 of them 2004 Vogue SE TD6
(Also a LR 90 V8 & RRS, just because)
Post #589539 30th Mar 2021 1:35pm
Sleepy Jen
United Kingdom 2008 Range Rover Vogue TDV8 Zermatt Silver
Mine are on the MOT advisories from last year, I have read that they can be changed on the car with a bush removal/fit tool for a BMW X5 - does anyone know if this is true???
Post #589581 30th Mar 2021 7:23pm
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
https://www.fullfatrr.com/forum/topic21092...r+subframe
Joe90 did it on the drive.
Post #589593 30th Mar 2021 7:57pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
I supplied them and a local garage charged £160 to fit them. 2010 VSE [Roger]
Post #589608 30th Mar 2021 9:49pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Yes the X5 subframe Bush Tool kit works as that's what I used on mine, e.g. Sealey VSE5585.
The advantage of the bush tool kit is you don't have to drop the subframe a massive amount from the body to extract or install the bushes. The subframe can be dropped using the damper lower attachment bolts in place of the subframe bolts as they are longer, with 2 bolts in opposing corners and the remaining removed it allows enough drop to use the tool. If you don't want to remove the damper bolts they are part number RYP000110/RYP000111.
It's the way it's done in the workshop manual and makes it pretty easy:
https://workshop-manuals.com/landrover/l32..._subframe/
Post #589760 31st Mar 2021 7:19pm
Sleepy Jen
Thanks Weejock. Thumbs Up
Post #589825 1st Apr 2021 10:03am
