Home > Technical (L322) > EGR BLANKED. No Fault Codes
Benjerbustmills
United Kingdom 2012 Range Rover HSE TDV8 Stornoway Grey
Hi
New to FFRR, & think it’s great.
I’ve had Land Rovers, a Hippo, for 5 years, & at the start of Lockdown 1, I bought a Friends’ 3.6TDV8 Vogue, who had had it from new. FMSH, but, as I had already blanked the EGR on my Hippo, I decided to blank the EGR’s on my Range. Got kit from EGR-Delete, and fitted it. Summoned a friend who remaps cars. Fitted the blanking kit ( was surprised at the clean state of the angled pipes, because the Hippo was choked. But the Range has had oil changes every 5K throughout her life), started vehicle, and got it hot. No fault codes. It runs excellent, and my friend reckons there is no need to map them out. I’m thinking of having a Stage 1 remap anyway, but do some TDV8’s NOT require the EGR’s to be mapped out??
Some people say yes, some no. What’s the consensus?? Thanks in advance.
Post #589438 29th Mar 2021 9:21am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
This is a bit long, but highlights everything I think I've I've learnt in the last 14 months before deciding what I'm going to do.
If the EGRs are mechanically blanked off while working OK, I don't think any of the 3.6TDV8s will generate fault codes just for being blanked off (my 2007MY car certainly doesn't & I've not heard of any MY that does, yet).
On the 3.6 TDV8s and probably the 4.4s, there is an electrical cross-check in the engine ECU software that checks actual movement of the valve head vs movement demanded, it might also check the current required. THe EGRs are fed a signal by the engine ECU to actuate them 10 times when either the engine starts or stops (I can't remember which). If the valve doesn't move as designed or the current is incorrect - eg due to partially sticking or fully stuck valve - the engine identifies a fault & lights up the Engine Management Light (EML).
This 10 times operation may also help to remove some carbon build up on the valve stem.
If the EGR is blanked off the cross-check still happens if its not been mapped out by a software tuner.
While the EGRs remain OK, no problems are reported & no fault lights will operate.
However, because the valve is still operating, it can still still fail electrically or mechanically - it's just highly unlikely to fail due to carbon build -up.
On my 3.6TDV8, on of the valves failed nearly a year after being blanked off - causing the EML to illuminate.
If you've got a diagnostic tester, you can identify the cause of the warning light & choose to ignore it as you know it's not an actual problem. However, at MOT time, it will cause an MOT failure, so does need dealing with.
To eliminate the EML warning you've now got 2 choices :
1 -changing the EGR for eg a known good s/h unit (its not important what the quality of the replacement is as its not doing anything functional for the engine - it just needs to "pass" the electrical test in the ECU OR
2 - getting a software tuner to delete it out of the engine ECU so it can't generate a fault code / EML illumination.
BTW I've seen nothing yet that clarifies what the software tuners actually do. They could "just" remove the output to the EML or they could prevent the EGRs from actuating & prevent any related fault codes.
If all they are doing is preventing the warning light operation, BEWARE, because if you don't mechanically blank the EGR off, it could still be operating & could still fail mechanically.
By now, most people should know that the worst case EGR failure is the valve head breaking up & being sucked into the engine & then going through the turbo(s), causing catastrophic engine damage (Incidents reported in this forum)
Removing the EGR fault codes via the engine software seems quite expensive with some of the reputable "mappers" - maybe because they are doing it safely & comprehensively & to me replacing the EGR ro remove the fault sems a much cheaper option, together with mechanical blanking.
I worry what the "cheap" mappers are doing to "delete the EGRs" - are they just removing the warning light operation OR are they doing it properly to stop the EGR operating ? If the former, don't waste your money - you could still have a future engine failure !!
THe only way to know what the tuner is actually doing is to couple up a "loose" egr to the relevant connector on the engine wiring loom & watch what happens when the engine is started & stopped (I've done this on mine, which is why I know about the 10 times operation check). If the EGR still moves, you've got a dangerous set-up that definitely needs the EGR blanking off !
PS If I've got any of this wrong, I'll happily update this, but it's all of the info I've gotten from various forums so far Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #589448 29th Mar 2021 11:15am
Benjerbustmills
Pawl
That is singularly the best and most comprehensive reply anyone can wish for!
Thanks very much.
I actually understand now, why my Range is not having a hissy fit! Like I said, the pipes I took off, although oily, were in great shape, with zero carbonisation.
However, when I did the Hippo, it was terrible. The EGR, was virtually inoperable, due to carbon build up, and sludge.
I also take on board your comments about Geeks just mapping out the light, whereas the question should be , “ Are you Disabling the EGR completely?”
Once again, thank You!!
Post #589465 29th Mar 2021 3:27pm
Excuse my ignorance, what is a Hippo ? .
Post #589468 29th Mar 2021 4:52pm
davidsmith1307
A freelander. Reference to the LR advert.
Post #589472 29th Mar 2021 5:19pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Specifically a Freelander 1. The nickname came from an advert Land Rover ran featuring a Freelander 1 in a river with two hippos in front of it.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #589492 29th Mar 2021 8:53pm
alfaalfa
Italy 2008 Range Rover Vogue TDV8 Zambezi Silver
Great response thank you on behalf of everyone considering this
Post #703337 29th Oct 2024 1:27am
bgennette
Australia 2003 Range Rover HSE Td6 Java Black
Pawl,
A 3rd option is to replace the EGR with a through pipe, but leave the removed EGR connected to the wiring.
Then do the EGR blanking at the exhaust manifold outlet. Cheap, easy and keeps the modules happy.
bye. 2003 TD6, EGR delete, vortex crankcase breather update, performance chip, UHF 2 way, Android head unit, crash camera on dash, always-on rear view camera to mirror screen, LED DRL`s, Electric trailer brake controller. FSR replaced. Pulling 3T caravan all about Australia
Post #709611 19th Jan 2025 1:51am
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
I blanked my EGR's and about 3 years later the EGR threw an error, cleared the faults and bought the map from BAS, no more errors.
Post #709677 19th Jan 2025 6:53pm
Pawl
bgennette wrote:
Pawl,
bye.
bgennette,
why bother with the through pipe ? Isn't it just adding more work to sort the EGR water pipes etc.
On mine, I blanked the EGRs at both ends & initially left the EGRs connected electrically.
As Red Hot One" I got EGR faults after some time (12 months on mine) and EML though.
I left the the faulty EGRs in place & just connected the engine electrical connectors to some good second hand EGRs - which can be easily changed again if they eventually fail and generate engine faults again. Paul,
Post #709931 22nd Jan 2025 11:06pm
