Home > Maintenance & Mods (L322) > Loud clunk when braking |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 793 |
I have asked before if anyone has experience of a loud clunk when braking at low speed, it was suggested it was a gearbox parking pawl safety feature. I am far from convinced as it seems to be getting louder. It occurs only on braking, even at the lightest touch of the pedal before the car has started to slow. It does not happen in reverse and is not apparent when the car is cold. From the driver's seat, it seems to be coming from the left rear, I have removed both rear calipers, cleaned and fitted new pads. I can find no excessive play in the subframe buses although have not counted them out. there is a little play in the top hub carrier bushes which have been ordered to change out. Any Ideas, I have read others having similar clunk but never tracking it down. Without touching the brakes there are never any clonks going over uneven ground or accelerating hard.
28th Mar 2021 2:59am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
Shock bushes can do this but to get an audible clonk they would need to have chunks missing...
28th Mar 2021 12:41pm |
paul70 Member Since: 06 Mar 2018 Location: North Yorkshire Posts: 101 |
My starting place would be the suspension bushes. When my upper arm bushes needed replacing they did clunk somewhat. They also caused my tyres to wear badly on the edges.
28th Mar 2021 6:07pm |
He said it comes from the rear... Pete
28th Mar 2021 7:44pm |
Haylands, thanks for the tips, I will check pad movement when I change to the top hub bushes. It makes sense the noise is coming from the pads and that's why I changed them, I did not think to check for movement. 2007 TDV8 VSE
29th Mar 2021 12:15am |
So today I received my new top hub carrier bushes which I changed out in record time, about 40 mins a side. I must say it's a delight to work on an 18-year-old car with zero rust. Pics are of both sides with the new bushes in. The good news is that after a quick test drive dabbing the brakes lightly there was not one knock so I am positive that was the issue. The not-so-good was once the hub was released from the top bush it was evident the bottom bush on the left side was in a bad way so that's the next job.
6th Apr 2021 8:17am |
If anyone needs to change out their hub carrier bushes this was the best video I could find which gives great insight into how to tackle the job. He was quoted US$2000 from a garage.
8th Apr 2021 4:52am |
