Home > Technical (L322) > hand brake light
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
hand brake light
dose not come on when the hand break is on
it comes on when the ignition is first turned on, then goes off
also, should there be a door warning light if the door is not closed properly RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #588815 25th Mar 2021 5:13am
knares
i meant to ask, where the fuse is for the hand break light RR 2005 4.4 petrol
Post #588816 25th Mar 2021 5:15am
knares
still looking for the hand break light fuse
found it in the Wiki manual
at 16 years old i was rewiring cars, i know things have changed but the wiring diagram is as clear as mud
while i was messing about i lost power to the cigar lighter, must have blown the fuse, so now i have an other fuse to find.
i have fixed the hand break light, it had a, must be, broken wire at the switch, soldered it on to the switch RR 2005 4.4 petrol
Post #589040 26th Mar 2021 1:35pm
mjdronfield
That’s good then. Can’t help with the cigarette lighter I’m afraid, though I imagine it’s easy to catch connections when stuff is taken apart.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #589052 26th Mar 2021 3:02pm
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
On my '09 Autobiography the fuses for the cigar lighters are in the back fuse panel. I know because I blew one on a recent trip.
Good luck!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #589067 26th Mar 2021 6:12pm
knares
its sorted now
thanks RR 2005 4.4 petrol
Post #589330 28th Mar 2021 9:56am
