![]() | Home > Maintenance & Mods (L405) > Silly mistake - topped up dynamic response with coolant! |
gerymor Member Since: 09 Apr 2012 Location: Derbyshire Posts: 35 ![]() ![]() |
Ok, so now I have drawn all of the liquid from the reservoir using a syringe and short tube. It was dark oil at the top and clear water below, so probably water has gone down the tube, or is there some kind of valve at the end? Anyway, is it worth topping up now with the correct fluid and crossing my fingers that I’ve got it all out? |
Dave G Member Since: 30 Jul 2020 Location: Dorset Posts: 84 ![]() ![]() ![]() |
My son did exactly the same on his in a hurry, had to have it drained and flushed through three times to remove the contamination, although he did top his up with antifreeze!
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 335 ![]() ![]() ![]() |
I echo Dave G's comments. Prior to my ownership mine had apparent been topped up with Ad-blu. The dealership flushed it several times, took them 3 hours. They said it was the 3rd one they seen. The two fluids had emulsified, so needed flushing.
Heard of this happening a lot! Why did JLR put that lid on it? |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1265 ![]() ![]() |
I would be wanting to flush the lot out ASAP as you know water is heavier than oil and some of that water you just know will go where you dont want it. Potential corrosion etc etc emulsifying and major loss of performance 2018 SE SDV8 4.4 Byron Blue |
Thanks for your comments everyone, kinda nice to know I’m not alone in this silly mistake. Anyway, I syringed as much fluid out as quickly as possible, then removed the tank and cleaned it out, syringed liquid out of pipes also and used a vacuum oil change pump to draw more. I’ve now topped it back up with the correct stuff and all seems well, no fault codes and seems fine going around roundabouts etc. So I’m keeping my fingers crossed for having saved an expensive dealer bill! Thanks for all the input guys. |
Hopefully you’ve been lucky. Give it a check in a week or so, depending on how much you use it, to check for emulsification. |
Lucky man! Might i suggest you change the fluid after 100 & 1000 miles just to be safe? |
