Home > Maintenance & Mods (L405) > Silly mistake - topped up dynamic response with coolant!
gerymor
Oh dear! How bad is bad? My 405 was flashing coolant low every time so I popped the bonnet and put a cupful of water into the reservoir. Oh no! It was the yellow cap Dynamic Response tank! Have not started engine, vehicle at home. Any advice gratefully received. Thanks
Post #588884 25th Mar 2021 3:01pm
gerymor
Ok, so now I have drawn all of the liquid from the reservoir using a syringe and short tube. It was dark oil at the top and clear water below, so probably water has gone down the tube, or is there some kind of valve at the end? Anyway, is it worth topping up now with the correct fluid and crossing my fingers that I’ve got it all out?
Post #588890 25th Mar 2021 3:27pm
Dave G
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
My son did exactly the same on his in a hurry, had to have it drained and flushed through three times to remove the contamination, although he did top his up with antifreeze!
Been fine since for him. 2013 Range Rover Autobiography 4.4 SDV8
Previous:
AMG C Class
AMG GLA
AUDI RS6
NISSAN GT-R x 5
Post #588972 25th Mar 2021 9:42pm
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I echo Dave G's comments. Prior to my ownership mine had apparent been topped up with Ad-blu. The dealership flushed it several times, took them 3 hours. They said it was the 3rd one they seen. The two fluids had emulsified, so needed flushing.
As you’ve not run your engine and therefore the pump, you may have gotten away with sucking out the contamination. If that is the case, you may be able to get away with a single fluid change.
The funny thing is, that I’ve not noticed a difference before and after. It was however put to me that you’d only notice it with "spirited" driving.
Post #588983 25th Mar 2021 10:46pm
Heard of this happening a lot! Why did JLR put that lid on it?
Post #588991 26th Mar 2021 12:21am
Kot
I would be wanting to flush the lot out ASAP as you know water is heavier than oil and some of that water you just know will go where you dont want it. Potential corrosion etc etc emulsifying and major loss of performance 2018 SE SDV8 4.4 Byron Blue
Post #589019 26th Mar 2021 10:25am
gerymor
Thanks for your comments everyone, kinda nice to know I’m not alone in this silly mistake. Anyway, I syringed as much fluid out as quickly as possible, then removed the tank and cleaned it out, syringed liquid out of pipes also and used a vacuum oil change pump to draw more. I’ve now topped it back up with the correct stuff and all seems well, no fault codes and seems fine going around roundabouts etc. So I’m keeping my fingers crossed for having saved an expensive dealer bill! Thanks for all the input guys.
Post #590143 3rd Apr 2021 6:33pm
millerj90
Hopefully you’ve been lucky. Give it a check in a week or so, depending on how much you use it, to check for emulsification.
Post #590148 3rd Apr 2021 7:56pm
Lucky man! Might i suggest you change the fluid after 100 & 1000 miles just to be safe? Thumbs Up
Post #590165 3rd Apr 2021 10:25pm
