Home > Technical (L322) > Is it possible to know what model a FF is? VOGUE, Autobiogra
harleyman
Spain
Hi,
I`m still looking for the right FF for me and I've seen cars that are advertised as Autobiography but comes with the VOGUE badge in the trunk and I would like to know it it is possible to know if it is a VOGUE or Autobiography as second hand prices are similar and I think that it it better going for the Autobiography that the VOGE or VOGE SE
Any easy way to be sure it is an Autobiography?
Thank you
Carlos
Post #589011 26th Mar 2021 10:57am
Dolphinboy
Autobiography models have a plate in the front of the engine bay saying autobiography and who built it (at least my 2004 AB does.)
Post #589012 26th Mar 2021 11:00am
harleyman
Spain
Thank you
with the info you´ve gave me I have found this
(Autobiography - Only differences between Vogue is different paint and interior colours and expanded options of the wood trim. Any car that is a Autobiography will have the Autobiography label inside the engine bay where the paint codes are, it is not a plate anymore just a label)
I would say that this one does not seem to have le label
Post #589015 26th Mar 2021 11:18am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
From 2008, Autobiography is just a regular trim level, not a custom order.
If something has a Vogue badge on the back, it seems safe to assume it isn’t an Autobiography.
Post #589016 26th Mar 2021 11:19am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Perhaps a non-technical way of spotting it is the leather roof lining on the autobiography for 2010 onwards models...A lot of the exterior clues are easily added but that isn't. So it would be either a very well specified Vogue SE (which isn't a bad thing) or an Autobiography. Or just get a 5.0SC it will have to be an Autobiography Rolling with laughter
In the UK you could also do a number plate check and it will give the registered details and should say AUTO behind the model...
Post #589023 26th Mar 2021 11:41am
Ask for the VIN, go to
https://topix.jaguar.jlrext.com/topix/vehicle/lookupForm
Enter the VIN and get the build sheet...
Another clue for the post 2010 is no piping on the seats, a French seam instead... Thumbs Up Pete
Post #589024 26th Mar 2021 11:46am
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
Unfortunately Topix no longer gives the build sheet unless you are a paid subscriber. It used to be free but that changed last year.
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #589068 26th Mar 2021 7:14pm
harleyman
Spain
That´s correct, I´ve tried and get an error
I use https://www.vindecoderz.com and so far it works quite well
Thank you
Post #589073 26th Mar 2021 7:41pm
That's a shame... Pete
Post #589119 26th Mar 2021 11:02pm
