Home > Technical (L322) > Beep on unlock |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7798 |
So if I remember right, the double beep means it thinks something is open, so it won’t lock or set the alarm..... is that what yours is doing? It’s not locking is it?
25th Mar 2021 10:23pm |
Steve_R Member Since: 14 Nov 2019 Location: Sussex Posts: 9 |
So,
25th Mar 2021 10:30pm |
Mine doesn’t beep at all, but I know you can change stuff for the alarm as below. Possibly correct, as you say, but worth looking in the settings to try it.
25th Mar 2021 10:48pm |
Thank you so much.
25th Mar 2021 10:49pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
OK, Do you have diagnostics equipment? Something like IID? You need to first check the CCF files as this is how the bleeps are switched off/on both on lock & unlock |
25th Mar 2021 11:45pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
CCF could have been updated as Craig says. Most of us have an IID Bluetooth. Invaluable for lots of things if you run an L322... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
26th Mar 2021 8:00am |
IID is on my shopping list!!
26th Mar 2021 9:52am |
One for sale on here just now Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
26th Mar 2021 10:38am |
Been out and about today, done a few miles, and now its stopped doing it.
27th Mar 2021 3:00pm |
No idea then. Wonder if it does something if the battery or backup battery for the siren is low? Not sure it even has a backup battery....
27th Mar 2021 3:18pm |
I'm wondering if it was telling me the cars batteyr was low??
27th Mar 2021 3:49pm |
I have my IID tool
30th Mar 2021 9:17pm |
Clear codes and see if it returns in a day or 2 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
31st Mar 2021 6:45am |
That’s good then. As above, clear it and see if it comes back, though from what you have found, it might start bleeping again.
31st Mar 2021 9:06am |
