![]() | Home > Technical (L322) > Replace 4.4 TDV8 engine, or sell the shell...? |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 595 ![]() ![]() ![]() |
First of all I'd get a second and even a third opinion. |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 294 ![]() ![]() ![]() |
First thing to do is get the fault codes read. Once they have been read you will have an idea of why it's in reduced performance mode. I would not trust a garage who simply said it's got metal in the oil without having the fault codes read.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 373 ![]() ![]() ![]() |
I would assume you’ve been referred to Simon Huntingdon at wigton. Simon and his his staff know there range rovers so should be able to give you a good idea of cost. He may be able to source a new engine or rebuild your existing one. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
As above, I wouldn’t do anything until you have had a full diagnosis carried out by a trusted Land Rover specialist.
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
If you're near Carlisle then I would definitely give Simon Huntingdon a call
Yorkshirelass Member Since: 27 Sep 2015 Location: Devon Posts: 4 ![]() ![]() |
Thanks, my wife is speakin to Simon as I'm in Africa at the moemnt. Cheers for the tip. |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Hi, if you are south of Carlisle then give Cumbria Landrover a call at Penrith, I take my FF to him for all works I can't do myself and he is spot on.
L322IT Member Since: 10 Aug 2017 Location: ITALY Posts: 17 ![]() ![]() ![]() |
what did you do to your engine then? |
