Home > Technical (L322) > Red or brown, well that’s obvious... isn’t it?
LowB
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
When faced with a red wire and a brown wire it would be reasonable to assume that red is positive and brown is ground wouldn’t it? Well apparently not if you’re Land Rover Confused
I discovered this recently when I replaced the standard H7 high-beam bulbs for LED versions. One way works, the other doesn’t. Oh how I’ve missed owning a Range Rover Laughing 2011 TDV8 4.4 Vogue SE in Galway Green with Black leather
1998 Saab 900 turbo convertible in Lime Gold with black leather
Post #588491 22nd Mar 2021 10:21pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
No it wouldn’t be safe to assume that. In automotive wiring, especially for British cars, red is normally the switch for the lighting circuit. And brown is the main battery feed.
Post #588494 22nd Mar 2021 10:57pm
LowB
Apparently so Smile 2011 TDV8 4.4 Vogue SE in Galway Green with Black leather
Post #588495 22nd Mar 2021 11:20pm
Martin
Site Admin
L322 originally used BMW wiring spec though, so brown=ground instead of the usual black=ground. But this did change on later models, from 2010MY I think the L322 had been completely "rewired" to LR spec colours.
Post #588508 23rd Mar 2021 9:07am
