Home > Maintenance & Mods (L322) > Rust Hole in Sill.
Chris1573
Rust Hole in Sill.
So after sanding away some rust bubbles on the rear arch
I decided to take the bull by the horns and took the sill cover off the O/S sill expecting to see the same disaster that people have posted previously. I think I have caught it fairly early.
The area around the hole is solid at the moment I have opened the hole up to the point where its solid and the jackmount seems OK... What's the best plan to sort this. I guess welding a plate in or over the hole would be one option along with treating the rust etc...
It would appear that the rust is starting at the holes that the plastic pin clips are pushed into. The one further down is showing early signs but is surface rust at the mo.
 L322 2007 TDV8 3.6
Post #588159 20th Mar 2021 3:51pm
The rust is forming inside the box section of the sill, the rust around the holes is where the rust is creeping to the outside of the panel, there is only one way to fix the hole and that is to cut back to solid metal and weld in a replacement piece that is butt welded to the hole, do not use a patch as the overlap will rust quickly and you will be back to square one...
When completed insure that rust treatment of your choice is injected inside the Sill.
Don't forget to remove the jacking points and all blanking plugs etc as there will be rust creep under them... Pete
Post #588167 20th Mar 2021 4:06pm
Chris1573
Hi Haylands,
How is the jackpoint removed ? L322 2007 TDV8 3.6
Post #588170 20th Mar 2021 4:10pm
Rog21
England 2012 Range Rover Vogue TDV8 Buckingham Blue
Prise out the plastic pin in middle of jacking point, you can then just pull or prise it off. L322 4,4 TDV8
Freelander 2 sold
Honda Transalp
Sunbeam S7 deluxe (in bits)
Sunbeam S8 (restoring)
Post #588171 20th Mar 2021 4:15pm
Chris1573
Thanks Guys, have removed jacking point, seems good and solid, Have used the dremel to cut back the rust. Just need to make a small piece to weld in place.... L322 2007 TDV8 3.6
Post #588175 20th Mar 2021 4:52pm
make sure you get some dinotrol or similar into the cill to try and stop the onward march. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #588178 20th Mar 2021 5:59pm
Chris1573
yep will do. Got a plate made just need to learn how to weld now Smile L322 2007 TDV8 3.6
Post #588214 21st Mar 2021 7:10am
Don't forget to disconnect the battery, a very small chance you may damage something if you don't but not worth chancing it in a fatty...!!! Pete
Post #588238 21st Mar 2021 11:30am
Chris1573
Yes thanks Haylands. However on reflection...
This is what it looks like now i have cut out the two areas where there were holes...
Clearly this area is a water trap as it was wet inside...
The Jack point is solid, and I don't think the two holes affect the structural strength...
I am thinking of fitting some plates over the holes with sealant that I can then remove as part of the annual check up. This way I can get to the area where the water gets trapped. I am even thinking of having some small holes to allow water to drain out.
Waiting for the KRust to do its thing...
 L322 2007 TDV8 3.6
Post #588244 21st Mar 2021 12:08pm
D3Jon
I'd definitely replace the metal you've removed by having a plate butt welded into place.
Especially with it being that close to the jacking point.
I'm pretty sure if an MOT tester could see the missing metal (if it wasn't behind a cover) he'd fail it.
Just my thoughts. 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #588247 21st Mar 2021 12:26pm
D3Jon
You've done all the hard work, just whip it to a garage with the covers off, etc. and have them make a patch and MIG it in place. Probably cost you £30! Smile 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #588248 21st Mar 2021 12:27pm
IIRC You can cut holes in bodywork as long as they are more than 12 inches from any suspension pickup point, seat belt anchor etc
Personally I'd have it repaired, inject the sills with good quality rust preventer and it will be fine for years... Thumbs Up Pete
Post #588255 21st Mar 2021 2:34pm
Chris1573
Thumbs Up L322 2007 TDV8 3.6
Post #588256 21st Mar 2021 2:45pm
Chris1573
Hi Guys, thank you for all the suggestions and advise. Its all back together now, the patch was welded up by a friend and done really well. The whole lot has been treated to rust converter, hammerite and a good coating of Lanoguard. I will be checking it before winter and applying more Lanoguard then... this will be a twice yearly thing going forwards its only a 5 minute job to remove the Sill protector so worth regular checks. Smile L322 2007 TDV8 3.6
Post #588745 24th Mar 2021 5:11pm
D3Jon
Thumbs Up Thumbs Up 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #588950 25th Mar 2021 7:44pm
