Home > Maintenance & Mods (L322) > Rust Hole in Sill.
Benjerbustmills
United Kingdom 2012 Range Rover HSE TDV8 Stornoway Grey
This is all caused by a design fault from JLR. They installed plastic capping over the inner wing, outer quarter panel lip, from the rear mudguards up to the point adjacent to the door on the rear quarter. Not extending that all the way round. Therefore the lip, became the rust trap. Mine started off just like yours, but you have to be brave enough to be brutal with it. As someone says cut it all the way back to clean metal. Fabricate a plate, & stitch it in. Grinding back the weld seams after. Liberally apply Jenolite to and surface rust areas & wait for it to change colour. Liberally apply Buzzweld Rust Encapsulator, leave to dry.
I then used Buzzweld War as a final coat.
Afterwards, you can either, use a strip of Freelander 1, wheel arch lip protector, and cut to size, or apply more war. I used war and lanoguard.
Jobs a goodun
Post #589631 31st Mar 2021 9:00am
Chris1573
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Benjerbustmills my arch was not too bad, the hole I had was caused by water that was inside the sill by the jackpoint. I have seen the mode to put the strip along the front edge of the Sill and I have bought some from Duckworths. L322 2007 TDV8 3.6
Post #589800 1st Apr 2021 6:57am
Teaspoonasaurous
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
Whats the standard cost of sill replacement at an indie. This is beyond my skills I think and the car has just failed its MOT due to rust issues.
I am wondering if I am better off throwing in the towel and changing her...
Post #589823 1st Apr 2021 9:58am
Very rarely a standard cost for welding work, if it's a small hole then it's worth doing, anything larger that has spread a lot and it won't be so cost effective... Pete
Post #589842 1st Apr 2021 11:12am
Teaspoonasaurous
MOT says structural issues with suspension due to corrosion...
Post #589920 1st Apr 2021 9:20pm
Ask the garage to be more specific, it maybe the subframes... Pete
Post #589923 1st Apr 2021 10:02pm
Teaspoonasaurous
The garage have declared the car, beyond economic repair... but have offered me a Disco 3 as replacement. Anyone have any advice?
Post #590535 6th Apr 2021 9:44pm
Get a second opinion, from someone who can look at it, not from a forum..... Thumbs Up Pete
Post #590559 7th Apr 2021 9:50am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
I agree with Haylands on this one, take it somewhere else and see what they say 2011 TDV8 Vogue SE
Post #590561 7th Apr 2021 11:06am
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I am doing my arches and sills at the moment. It's a horrible job and as the replacement panels are not readily available there is alot of fabrication or trying to find rust free used parts. There are now outer wheel arch repair panels available but if your body has rusted through the liklyhood is that the inner wing and sill has gone as well and these panels are not available as repair panels.
Post #590673 8th Apr 2021 5:37pm
