Home > Technical (L322) > Rear Discs |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3108 |
If you scroll down to the bottom of this page there's links to the workshop manual that you should be able to see.
18th Mar 2021 4:55pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6730 |
Or, if you have an IIdTool, it will do it for you Got - 2017 SDV8 Autobiography in Loire Blue
18th Mar 2021 5:01pm |
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 |
Yes I downloaded the manual David. there is a link in there to an external JLR site that I can access. L322 2007 TDV8 3.6 |
18th Mar 2021 5:34pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 693 |
If you didn't change the EPB shoes, there's no need for the bedding process - which is more for the EPB shoes than the discs Paul,
18th Mar 2021 5:56pm |
So just tighten up the adjuster till they grip then back off a few clicks till they don't Pawl ? L322 2007 TDV8 3.6 |
18th Mar 2021 6:07pm |
There is a specific quanity of clicks to back-off I think - probably to ensure the EPB applies the correct tension to the cable.
2001 Discovery 2 TD5, 211,000 miles & climbing 2006 FFRR TDV8 Vogue 151,000 miles & now sold Member of Midland (Land) Rover Owners Club, www.mroc.co.uk |
18th Mar 2021 6:31pm |
18th Mar 2021 7:02pm |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 178 |
I replaced the disks and pads earlier this year but not the EPB pads, I did have to go through the palaver of the resetting of the pads for the handbrake. not difficult but does take a bit of time and I don't think doing it in the centre of a city or town works. I did mine on a rural road, it did take about 8 or so goes to get the brakes set, it did pass an MOT so I must have done something right. |
18th Mar 2021 7:11pm |
Sleepy Jen Member Since: 15 Feb 2021 Location: Basingstoke Posts: 32 |
There is a good how to video on You Tube from Powerful UK Ltd - Land Rover Discovery 3 & 4 bedding in rear handbrake shoes EPB. It is for a Disco 4, but the sytem and procedure is the same for L322's.
20th Mar 2021 6:55pm |
Thank you SJ... L322 2007 TDV8 3.6 |
21st Mar 2021 7:20am |
