Home > Technical (L322) > L322 3.6 TDV8 Soot from exhaust under acceleration. Normal? |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 738 |
Not normal-has it ever been chipped? |
17th Mar 2021 10:03pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1468 |
I only bought the car a few months ago so, no idea if it's been chipped.
17th Mar 2021 10:39pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 |
Black smoke is mostly an air leak on the intake somewhere, though it would do it every time I would have thought, not just once.
18th Mar 2021 12:00am |
The cloud is pretty much each and every time I floor it. Just a quick puff of soot and then it goes clear again. If the revs stay below around 3,000, there is no soot/smoke.
18th Mar 2021 12:20am |
You’re right to try a different mechanic as a visible cloud is not normal. If new filters don’t sort it, it drives OK and has no fault codes stored then a poor quality remap could cause your problem as some just dump a bit extra fuel which is what yours sounds like it’s doing. |
18th Mar 2021 2:10am |
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 |
Which turbo hose leaked oil... ? L322 2007 TDV8 3.6 |
18th Mar 2021 3:48am |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
I agree, it sounds like its overfueling. If it hasn't got a bad quality (or too high setting) tuning box on the fuel rail, then I suggest it may have had a generic remap loaded on it. |
18th Mar 2021 6:02am |
It was the oil feed pipe on the nearside turbo. |
18th Mar 2021 7:02am |
Very interesting that 3 people have now suggested the cause as a remap / tuning box.
18th Mar 2021 7:21am |
May have had an ECU remap ? I assume that with a diagnostic tool they can see if it has... L322 2007 TDV8 3.6 |
18th Mar 2021 7:38am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Gary
18th Mar 2021 8:00am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
i had this on a grand cherokee 2.7TD once tried everything including a new turbo!!
18th Mar 2021 8:17am |
2nd garage, 2nd opinion.
18th Mar 2021 6:06pm |
Whilst I have the 4.4 TDV8, it still doesn’t sound right to me.
18th Mar 2021 6:19pm |
