Home > Technical (L322) > L322 3.6 TDV8 Soot from exhaust under acceleration. Normal? |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1468 |
Given I have the same answer from two trusted local garages, who have both seen in person, I think the conclusion is that neither are concerned and, it could be a number of things. I think the answer is to monitor, run some cleaners through the fuel and induction systems and run on premium diesel and just see if it clears up, remains the same or gets worse. If it gets worse then, I know it's something failing and it will need to go to a garage It may resolve itself, if oil was making its way from the leaking rocker cover gaskets onto the injectors. Now that supply of oil has stopped, it may just need time to burn everything off (and be hot enough to do that). I think the key is to do the obvious things first and monitor for a month or two. |
18th Mar 2021 8:06pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 |
Indeed. Sounds like a plan.
18th Mar 2021 9:06pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3235 |
Having read your posts re smoke, I was out today so took the opportunity to see if there was any comparison. Took the car up to 3500 rpm and not a trace of smoke.
19th Mar 2021 4:24pm |
I'll run for 2 or 3 weeks, get some good motorway runs through it, fuel system cleaner, induction system clean / turbo clean and go from there.
19th Mar 2021 4:57pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Most folks in the know reckon Terraclean = snake oil Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
19th Mar 2021 5:40pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
In my opinion...excessive carbon build up in exhaust this is not based on the description. I mean, ok it may not have a DPF but it is still relatively modern turbo diesel technology.
19th Mar 2021 6:13pm |
You know what, I'm beginning to think it's a remap.
19th Mar 2021 6:44pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
EGR valve is it blanked or still in place? they can cause these symptoms when not working properly 2012 Vogue 4.4 TDV8 - Current
19th Mar 2021 7:01pm |
In the meantime, I have thoroughly checked both top intercooler hoses and they are both in good condition, properly sealed and don't seem to be more than 3 or 4 years old.
21st Mar 2021 11:29am |
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 74 |
If you dont have any diag gear which you will more than likely have to have to get any idea of what is happening here id be doing the simple things you can easily do which may well be a cause like cleaning the air flow sensors and intake boost sesnors etc... easily done plenty of info on here about it
21st Mar 2021 3:09pm |
I think I may have an idea, as diagnostics showed no issues on the PCM after clearing old codes.
22nd Mar 2021 11:07am |
So, the mystery got solved.
9th Apr 2021 9:37pm |
Nice one. Never saw issues like this on my 1981 Fiesta. There’s progress for you 🤣.
9th Apr 2021 9:53pm |
