![]() | Home > Technical (L405) > Can anyone explain how the P400e hybrid engine works? |
mikef Member Since: 30 Jan 2013 Location: Bucks Posts: 82 ![]() ![]() ![]() |
I'm 6 months into the ownership of a L405 P400e. For anyone who doesnt know, the drivetrain consists of a 300hp 2.0L petrol engine and 104hp electric motor with a claimed total power output of 404hp.
Reassured I went ahead and ordered the car. Now 6 months later I'm beginning to wonder whether the salesman was right all along. When there is charge showing in the battery, the acceleration is satisfyingly brisk and it feels like all of those 404 horses are present and correct. However, when there is 0% charge showing, the performance feels significantly less brisk and the petrol engine becomes more thrashy as if its having to work a lot harder So who's right, the salesman or L-R? Or is the truth somewhere in between in that the electric motor will only contribute if it has sufficient regenerated battery capacity but as soon as that is exhausted, the petrol engine is on its own? |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 793 ![]() ![]() ![]() |
I have exactly the same impression. When there's zero battery, the power is reduced. It's true that the engine and regen braking will charge the high voltage battery, but only up to 10%, they say (probably the fuel consumption would be huge otherwise). Also, at standstill, while the engine charges the battery, there's a disturbing low rumble, that the dealer believes is absolutely normal...
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Typical bullshit given out by most Hybrid manufacturers i.e. 101 mpg, no way and the 404bhp always being available, how can it? if you've used all of the battery then 104bhp is missing, you cant magic the energy out of nowhere.
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 ![]() ![]() ![]() |
Surely 300hp is not that bad seems like a load of hp compared to say a tdv8 is pretty spritely on less than 300...? L322 2007 TDV8 3.6 |
Yes it doesnt sound too bad but dont forget this is a 2 litre petrol engine so the 300hp is only available right at the top end and it is pretty gutless in the low and mid ranges. Also dont forget that it is hauling around an additional 300kg or so of batteries. As I said above, personally I would prefer a 6 cylinder petrol or diesel engine, even if it made the same 300hp, simply because there'd be more mid range shove With the P400e engine when it runs out of battery and you are reliant on the 2 litre petrol engine, you have to rev the nuts off it to get any kind of performance and thats really not how a RR should drive |
The real fuel consumption with zero battery is between 10.5-12 l/100km (27-23.5mpg).
Agreed. I get about 25mpg when the battery charge is 0% |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Reading this reminds me of when I went mad and bought a Prius a while back. I really dislike underpowered vehicles with screaming engines. I traded that one in for a Mercedes AMG GLS63 aka the anti Prius.
ilard Member Since: 21 Oct 2012 Location: London Posts: 712 ![]() ![]() |
The factory equipment that lifts the phev battery is rated to max 160 kg, so I presume the battery is less than 160 kg. I took a photo of it on my factory visit.
ilard thanks for your input. When I was ordering my RR back in summer of last year (a right PITA that was) IIRC the P400e was about 250kg heavier than the D300 version which I was also considering. In truth I went for the P400e not because I preferred it (I couldnt actually get a test drive in either vehicle) or because I wanted to save polar bears but because the contract hire rate was cheaper and the dealer offered me a stock car. Having done so though I decided to do it properly by having 7kW chargers fitted at home and work. If I'm honest I'm getting fed up plugging/unplugging the car twice a day and I certainly miss the performance of my previous car, a RRS SDV8 so the jury is out for me so far as what I replace this car with when the time comes
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 784 ![]() ![]() |
I said the same on the other thread, but everyone with a hybrid seems to conveniently ignore the cost of electricity and just quotes mpg and compares that to a conventional combustion engined car. If you do a lot of short journeys, then that will still be a lot cheaper than the low mpg you'd get, but cost per mile is the only fair comparison. If you're that bothered of course! MY23 Panamera E-Hybrid
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1453 ![]() ![]() |
We all have FFRR - what do you think....... ![]() ![]() ![]() 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
Youre right. Charging is not a huge cost something like £0.04/mile so sticking a finger in the air and saying that 60% of the 7000 miles I've done so far have been in EV mode thats a total cost of £168. The other 40% has been powered by the petrol engine at say 25mpg, thats £672 of petrol at £1.30/litre, total £840 or £0.12/mile If the whole 7000 miles had been powered by the D300 diesel engine at an average consumption 32mpg with diesel at £1.40/litre (I only buy the expensive stuff!), then I would have spent £1390 or £0.20/mile so, so far, I'm saving about £0.08/mile which, over 3yrs/45000 miles is £3600 The contract hire rate was about £100/month cheaper on a 6+36 deal so thats £4200 saved there. There is also a saving on the car tax but I cant remember what it is but on the other hand I've spent about £1000 on 2 new chargers to offset that. But a total fuel+financing saving of £7800 over 3 yrs is not insignificant. Whether its worth it in terms of what I consider to be a somewhat less inspiring driving experience is a moot point! |
