![]() | Home > Technical (L322) > 4.4 identifying an oil leak |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2663 ![]() ![]() |
The cost for the gasket replacement might indicate the work time involved which may align with the cooler gaskets replacement but you could replace the o-rings with minimal effort and cost to see if the leak stops. |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
I assume you have removed the cabin filter scuttle to inspect?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Oil feed looks wet.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Clean, replace O rings, monitor.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 910 ![]() ![]() ![]() |
I'd also be tempted to look deep down in the vee where the oil cooler sits.
