Home > Technical (L322) > 4.4 identifying an oil leak |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2495 |
The cost for the gasket replacement might indicate the work time involved which may align with the cooler gaskets replacement but you could replace the o-rings with minimal effort and cost to see if the leak stops. |
16th Mar 2021 8:07pm |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 |
I assume you have removed the cabin filter scuttle to inspect?
16th Mar 2021 9:05pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8620 |
Oil feed looks wet.
16th Mar 2021 9:31pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
Clean, replace O rings, monitor.
19th Mar 2021 7:59am |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 899 |
I'd also be tempted to look deep down in the vee where the oil cooler sits.
19th Mar 2021 9:04am |
