Home > Maintenance & Mods (L322) > Upper bootlid rubber strip removal
Danwilderspin
Hi all got a new bootlid that needs painting!
Can you remove the rubber strip between the painted area and the glass? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #587474 14th Mar 2021 9:06pm
mjdronfield
Yes, I believe it slides out sideways. Might be hard getting going due to age.
When I got mine done on my TD6, I paid someone to remove the glass too, as the replacement tailgate was a completely different colour.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #587476 14th Mar 2021 10:03pm
Danwilderspin
I see - thanks I will soak it in brunox and see how we get on Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #587484 14th Mar 2021 11:53pm
p38arover
Australia
Mine was falling apart so I took a block of wood, sat it against the end of the strip and tapped the wood with a hammer to drive the strip out. It's too tight to just push out.
Once I had enough pushed out, I was able to grip it in my hand and pull it the rest of the way. I didn't replace it as later models don't have it.
It did leave a line on the painted surface where the edge of the rubber had dug into the paint over the years. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #587503 15th Mar 2021 9:01am
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
As mentioned above, it is unlikely to slide out. Dirt and deteriorating rubber tend to seize it soild into place.
Work the side edge loose with a thin block of wood or, extremely carefully NOT to touch the glass, with a screwdriver and a mallet. Once enough length has been removed to give you grip for a pair of pliers just pull the thing away along the glass bottom by pliers first, hand then.
You won't need to fit another one. LR did away with the rubber strip on later models.
Post #587525 15th Mar 2021 10:25am
dhallworth
I removed it from my last L322. I used a brass drift and a hammer and started tapping it from the OS to the NS and once it was part of the way out I was able to do it by hand.
Again, I didn't replace it as the newer cars don't have it and I thought the lines looked much cleaner without it. I'm probably going to remove it from this SC we've got now too.
It did need quite a "tap" to get it to start moving IIRC.
Post #587541 15th Mar 2021 12:58pm
