![]() | Home > Maintenance & Mods (L322) > Upper bootlid rubber strip removal |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Yes, I believe it slides out sideways. Might be hard getting going due to age.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
I see - thanks I will soak it in brunox and see how we get on Current stable:
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1543 ![]() ![]() |
Mine was falling apart so I took a block of wood, sat it against the end of the strip and tapped the wood with a hammer to drive the strip out. It's too tight to just push out.
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 594 ![]() ![]() ![]() |
As mentioned above, it is unlikely to slide out. Dirt and deteriorating rubber tend to seize it soild into place.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3146 ![]() ![]() ![]() |
I removed it from my last L322. I used a brass drift and a hammer and started tapping it from the OS to the NS and once it was part of the way out I was able to do it by hand.
