Home > Maintenance & Mods (L322) > 2010MY+ CCF Editing
Page 5 of 5 <12345
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Speedo setting
Hi all
Need a bit of help here please. Today successfully enabled Drls and got as far as changing the speedo to Kph with the mph set in the digital readout in the centre. Problem I now have is that I can't change back the main speedo to show mph as before.
Anyone had this happen to them and if so can you let me know what I am doing wrong as I am missing something - hopefully!
I've been going round in circles.
regards
Dave
Post #587187 12th Mar 2021 3:59pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Dave,
From memory -- you go into the car menu and change it back after you've used IID -- should then leave you with both in MPH -- though I am getting old and memory is failing ! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #587189 12th Mar 2021 4:29pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
I must admit, I'm confused as to why UK based drivers would want the main dial in kph and the digital one in mph.
I've gone for the other way round which will do me just fine if I ever take it abroad and need to use kph.
(Yes, I've sorted the date out since I took the photo!)
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #587193 12th Mar 2021 4:40pm
when i travel abroad i have the main dial as KPH and the digital as MPH so i can get an idea of the KPH speed [if that makes sense] ... - .- -.
Post #587205 12th Mar 2021 5:38pm
Nylands
Well folks that is where I’m stuck, so can Stan explain to me how he gets it back to mph on the main Speedo layout please. I can set it up if I get abroad after these lock downs. Not sure where to find any settings other than the trip settings and I have that as mph, mpg etc from the steering wheel?
Thanks Dave
Post #587208 12th Mar 2021 6:16pm
i havnt a 2012 anymore so i cant remember where in the menu the setting is but its defo there..
unless you have done something in the CCF that wont allow this.. ... - .- -.
Post #587211 12th Mar 2021 6:54pm
this is from a thread on the forum,
Post #587216 12th Mar 2021 7:18pm
Nylands
Thanks for the update Stan. I may have not used the OK button after selecting mph etc buttons etc. and that could be it. Could be something that simple and I will try that out tomorrow.
Many thanks Stan
Dave
Post #587238 12th Mar 2021 10:32pm
Nylands
Got it sorted this morning and back to mph etc. I was missing the important link - the line on Ccf “ Main Scale “ and therefore not changing back to mph!!! This had been mentioned on the previous posting but the old grey cells needed a bit more time.
Thanks Stan and everyone for saving a embarrassing trip to a garage.
Regards
Dave
Post #587262 13th Mar 2021 9:57am
DrRob
Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #587270 13th Mar 2021 10:22am
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
On our FL2 the radio mute when the PDC picks up something.I find it very handy and would like to know if this is possible on my 2012 FFRR?I have a Iid tool. 2012 TDV8 Vogue SE 4.4
Post #587894 18th Mar 2021 3:45pm
not seen that adjustment in the menus... ... - .- -.
Post #587901 18th Mar 2021 4:00pm
frbodya
PatGAPInnov wrote:
Certainly, once you have a tool on hand, send me a PM and I'll arrange it Thumbs Up
Hello, as I just registered couldn't send pm. You could confirm that with IIDTool BT G3 I could change from kph to mph(main speedometer) I have l322 (2010) as I want to register car in uk I need fully mph speedometer.
Post #648796 21st Nov 2022 9:11pm
if its a digital speedo then the mph to kph can be selected in the menu.. ... - .- -.
Post #648804 21st Nov 2022 10:01pm
frbodya
by some reason, I have only 2 option mph/kph and it switch everything and digital(with numbers) but main speedometer still in kph(round one). Maybe that car is from Ukraine and they give this 3 options only for UK car, not sure
Post #648805 21st Nov 2022 10:02pm
Page 5 of 5 <12345
