![]() | Home > Maintenance & Mods (L322) > 2010MY+ CCF Editing |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1294 ![]() ![]() ![]() |
Must have another go at my drl's. When I tried last time they didn't work and it also stopped the electric windows going up and knocked out the distance warning!! |
neilly Member Since: 06 Oct 2019 Location: Oxon Posts: 79 ![]() ![]() ![]() |
For some reason, it told me the update had failed, but in reality the changes worked.
TJRL Member Since: 07 Sep 2019 Location: Reading Posts: 198 ![]() ![]() ![]() |
Any tips for an ID tool novice on how you did this? 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD ![]() 1960 Land Rover SII SWB SW 2020 BMW R1250 RT LE 2021 Triton ST-125 (Monkey Bike) |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Same here today
Also the windows need to be rest to one push close.
Yes, I locked it, restarted and all was good. Loads of warnings flashed up before that saying abs, Tc etc not working but locking and then unlocking and starting up sorted it all out.
I had mine on the CTEK for a few hours beforehand. Afterwards I checked the %age state on the IID. 85%. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 85 ![]() ![]() ![]() |
Got the IID tool plugged in this morning and activated the digital MPH display on my dashboard! Happy days! 🙂
Got some LED number plate light bulbs to fit but will use IID to disable the cold test to avoid them flashing as part of a bulb check:
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
Has anyone enabled the amber front markers?
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520 ![]() ![]() ![]() |
Is it possible to have the digital readout as kph with the main dial in mph?
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
Hi Dr Rob
Try the onboard menu. If not, in another part of IID menu for CCF update as per digital window... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I’ll try another go at it. Sometimes pays to take a break. Let you know if successful.
