Home > Maintenance & Mods (L322) > 4 Pot Brembo conversion.
grey17
United Kingdom 2010 Range Rover Vogue SE TDV8 Alaska White
Hi all.
I've relatively recently bought a 2010 3.6 L322 and whilst it is superb in many ways, I find stopping it sometimes a bit worrysome when compared to my previous Brembo equipped car.
As a potential lockdown project, I am considering upgrading it to 4 pot Brembos and have a couple of questions.
I'll refurbish some used calipers but wanted to check that there was just the one part number covering the 4 pots, namely SEB500390?
Is the brake master cylinder fitted to my 2010 car the same as a factory Brembo equipped car?
Other parts I'll need are new discs, pads, flexi hoses and back plates, anything else I should be aware of?
I'm sure someone here has done this so any links would be super helpful as I could only see one for a 6 pot conversion.
Thanks in advance Smile
G
Post #587016 11th Mar 2021 11:32am
robster3.6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Hi Grey17,
This is something I've been looking into for my MY10 3.6TDV8, I did do a bit of research a while back on this fantastic forum and I think you need to change the hubs also (I maybe wrong it was around 6 months ago I looked into it) I think the calliper mounting holes on a MY10 are different and will not accommodate the Brembo Caliper unless the hub is changed....
Have you started to accumulate any parts yet?
Rob
Post #587024 11th Mar 2021 12:32pm
grey17
Hey Robster.
Great to hear from you and thanks for your reply...... nice to know that there is someone else out there considering the same upgrade.
I've not heard about the hubs being different as they are the same part number from 2002 - 2012 and link here for reference.
https://www.lrparts.net/lr023978-front-hub...-2012.html
I've got my local main dealer doing a parts search and compatibility study to see exactly what I need and what I already have that can be used again.
I'll share once I've got the information.
Very best.
G
Post #587067 11th Mar 2021 4:47pm
mjdronfield
https://www.fullfatrr.com/forum/topic36384...bo+upgrade
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #587075 11th Mar 2021 5:09pm
GraemeS
IIRC you would need the 4-pots from a RRS as that version has the larger mounting holes. MY10-12 have the same size holes as all RRS, D3 & D4, larger than the earlier L322.
The appropriate pad wear sensor lead will be required.
Post #587104 11th Mar 2021 8:02pm
Mikey
And if your going to upgrade to 4 pots, you may as well upgrade to 6 pots Thumbs Up
Post #587115 11th Mar 2021 8:47pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Wouldn't 6-pots limit wheel size, though?
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #587117 11th Mar 2021 8:50pm
GraemeS
Compomotive 18" fit over the 4-pots but not 6-pots.
Post #587139 11th Mar 2021 10:49pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Thumbs Up Thumbs Up Thumbs Up
Totally agreed. One may as well...
But...In general I wouldn't do it at all. I would just stick to the basics and make certain my master cylinder and lines work well, my fluids are fresh, and my discs and pads are good. The braking power will be plenty to stop it. The bigger Brembo's are just well that, bigger. But also add extra weight most likely. And still don't give the sensation of super brakes anyway. I think it would be a waste of money project with very limited measurable benefit.
Post #587146 12th Mar 2021 5:54am
DaleL322
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
Hi G
I am in the same boat, 2009 facelift 3.6 with standard brakes
I've scoured the net and not actually found anyone who has completed a 6 pot 4.4 tdv8 brake upgrade yet
My understanding was that we will require the hubs from a donor 4.4 too so if you now differently please let me know Thumbs Up 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
https://www.fullfatrr.com/forum/topic58777.html
Post #587580 15th Mar 2021 4:30pm
why scour the net when you can look in our wiki, Thumbs Up
https://www.fullfatrr.com/forum/topic33462.html ... - .- -.
Post #587583 15th Mar 2021 4:41pm
DaleL322
Stan I even looked... clearly couldn't see the wood through the trees.. cheers!! 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
Post #587586 15th Mar 2021 4:56pm
grey17
I contacted my local main dealer to get the gen straight from the horses mouth so to speak on the Brembo conversion and what parts are needed.
So, here is a definitive list with part numbers and prices. This is for a 6 pot Brembo conversion and it seems that all components are interchangeable or, no change or confusion about mountings and bolt holes. Copy and paste:
After a bit of research on my parts catalogue I can confirm the calliper mounting points, hubs and master cylinder are the same. The rear brake set up is mostly the same on both vehicles however the pads have a different part number. The parts required for a front conversion are as follows:-
Callipers- LR139257 & LR139255 -£779.33 Per Side + VAT
Discs- LR031845 -£86.10 Per Side + VAT
Disc Securing Bolt- SDG100000L - £0.90 + VAT (X2)
Pads- LR114004 -£276.53 + VAT
Pad Wear Sensor- LR012824 -£22.66 + VAT
Flexi hoses- LR075628 -£37.34 Per Side + VAT
Disc back Plates - LR011721 & LR011722 -£35.69 Per Side + VAT
Disc Plate Bolts- LR018509 -£0.66 + VAT (X6)
New mounting bolts- SYG500050 -£4.63 + VAT (X4)
The Flexi hoses are the same as those currently on the vehicle however I would advise if you do go ahead with the conversion to replace them.
Looks like a project for a little later the the weather warms up a bit!
G
Post #587679 16th Mar 2021 4:25pm
Mikey
I've a pair of 4 pot calipers here. Only £700 a side Whistle Laughing Laughing Laughing
Post #587714 16th Mar 2021 9:26pm
briangunn
United Kingdom 2010 Range Rover Vogue SE TDV8 Buckingham Blue
DaleL322 wrote:
Hi G
I have. Six pots fit on a 2010MY (facelift with TFT instruments) 3.6 - you don't need the hubs.
I balanced with the rear brakes from a 4.4, too, as the rear discs are bigger - calipers, carriers and discs. All of the parts (apart from wearing parts) came from a donor 4.4 on eBay..
Post #587725 16th Mar 2021 10:11pm
