![]() | Home > Maintenance & Mods (L322) > 4 Pot Brembo conversion. |
robster3.6 Member Since: 06 Jan 2021 Location: Devon Posts: 6 ![]() ![]() ![]() |
Hi Grey17,
grey17 Member Since: 31 Aug 2018 Location: ha6 Posts: 65 ![]() ![]() ![]() |
Hey Robster.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7906 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic36384...bo+upgrade
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2642 ![]() ![]() |
IIRC you would need the 4-pots from a RRS as that version has the larger mounting holes. MY10-12 have the same size holes as all RRS, D3 & D4, larger than the earlier L322.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1808 ![]() ![]() |
And if your going to upgrade to 4 pots, you may as well upgrade to 6 pots |
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520 ![]() ![]() ![]() |
Wouldn't 6-pots limit wheel size, though?
Compomotive 18" fit over the 4-pots but not 6-pots. |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
![]() ![]() ![]() Totally agreed. One may as well... But...In general I wouldn't do it at all. I would just stick to the basics and make certain my master cylinder and lines work well, my fluids are fresh, and my discs and pads are good. The braking power will be plenty to stop it. The bigger Brembo's are just well that, bigger. But also add extra weight most likely. And still don't give the sensation of super brakes anyway. I think it would be a waste of money project with very limited measurable benefit. |
DaleL322 Member Since: 04 Mar 2021 Location: Stamford Posts: 176 ![]() ![]() ![]() |
Hi G
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
why scour the net when you can look in our wiki, |
Stan I even looked... clearly couldn't see the wood through the trees.. cheers!! 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
I contacted my local main dealer to get the gen straight from the horses mouth so to speak on the Brembo conversion and what parts are needed.
I've a pair of 4 pot calipers here. Only £700 a side |
briangunn Member Since: 19 May 2019 Location: London Posts: 56 ![]() ![]() ![]() |
I have. Six pots fit on a 2010MY (facelift with TFT instruments) 3.6 - you don't need the hubs. I balanced with the rear brakes from a 4.4, too, as the rear discs are bigger - calipers, carriers and discs. All of the parts (apart from wearing parts) came from a donor 4.4 on eBay.. |
