Home > Maintenance & Mods (L322) > Air con heater/heated screens control panel dead 2002 vogue
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
Yesterday evening I switched on my heated windscreen and the light came on for a few seconds then went out now the air on panel is dead no power to heated windscreen or rear windscreen and heater controls all dead.
I have checked all the fuses in the glove box and all fine.
Is there a fuse link in the rear fuse box that feeds the control panel? Where else can I look? Any help greatly appreciated.
Post #587026 11th Mar 2021 12:42pm
Merchy
https://www.fullfatrr.com/forum/topic58706.html
If I have done this right, the above may help, if wrong, the luddite strikes again!
A/C - Heated screens etc panel is one block, with all functions running through an internal PCB, link will show the unit and how to remove, sounds like failure of the unit is possible if supply fuses to the panel are OK
Checked some pics and looks like the 2002 panel is the same as my 2006 one, hope this helps.
Post #587032 11th Mar 2021 1:00pm
horsedentist
Thanks for that
Post #587034 11th Mar 2021 1:12pm
