Home > Maintenance & Mods (L322) > Coolant query |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8245 |
If you put your registration number into Halfords it will tell you which ones will suit... Pete
8th Mar 2021 10:44am |
Dode4444 Member Since: 18 Jan 2021 Location: Buckie Posts: 43 |
I did do that and Halfords comes up with the silicate variant where as I have read some posts on here saying I need the OAT type so was just trying to confirm.... 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black |
8th Mar 2021 11:03am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3163 |
If you already have orange (OAT) in then use that. Don't mix as the blue and orange react and form a gel like substance which clogs the system (so I have reliably been informed). There is lots on here ref coolant so a search might provide further authority. |
8th Mar 2021 11:11am |
Thanks for the replies folks, have searched several times and yet again get conflicting advice.
8th Mar 2021 11:15am |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 435 |
Halfords checker can't be right as it comes up with every type of coolant under the sun for my FFRR when I put the registration in, G48, G40, OAT, Silicate based, etc. Don't know if that's just me?
8th Mar 2021 11:30am |
Halfords brings up silicate and g48 based on my reg number.
8th Mar 2021 1:13pm |
Having just had my oil cooler changed by my outstanding, 25 yr LR experienced indie, along with a full coolant change, he has put this in. But mines a diesel 4.4TDV8 - just seen yours is a SC 4.2 so may be different.
8th Mar 2021 1:29pm |
Triumph72 Member Since: 11 Apr 2018 Location: Argyll Posts: 39 |
I use Prestone in any car I needed it for, it will mix with any car coolant no need to worry.
8th Mar 2021 1:48pm |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Use OAT in mine. Previous cars:
8th Mar 2021 4:41pm |
Thanks for the help and replies people.....
8th Mar 2021 5:35pm |
