![]() | Home > Maintenance & Mods (L322) > Rear washer leak repair - the cheaper option! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35484 ![]() ![]() |
all credit to alanm_3
Rear wiper leak repair additional tips.
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 ![]() ![]() ![]() |
Just to add to the above, you can also use a small flat blade to pry out the original seal then replace with the new one mentioned above. The plastic fitting then sits flush when you re-seat it... Sorry Stan just seen that you already did this |
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
Seeing photos of that motor brings back traumatic memories. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3146 ![]() ![]() ![]() |
I’ve just done this repair today.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6741 ![]() ![]() ![]() |
Glad it helped David |
I hate to play the ghoul, but if your experience is anything like mine, other failures are looming in the near future. When you get to the end of being able to repair the unit, you can make a new working one from a brand new replacement (incompatible with pre-facelift) motor and your old one:
I caught mine early enough that it was just a dribble leaking and there was barely any crap inside the motor.
I too felt the warm glow of success when I too had swapped an o ring.
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 ![]() ![]() ![]() |
I need to get the 10x16x4 Radial Oil Seal mentioned above, but link is now out of date.
I fitted this one to my car in Feb 2021 and haven't had any issues with it since.
Might be worth ordering this as well just incase you find any wear inside the motor when you open it up:
Amazing-thank you.
Hopefully i wont need that. I have taken it all apart and there was minimal rust, which i cleaned off and the gear looks perfect. I have put it back together temporarily while I await the seal, and its wiping well ![]() |
