Home > Maintenance & Mods (L322) > Rear washer leak repair - the cheaper option! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35263 |
all credit to alanm_3
12th Feb 2012 5:16pm |
Rear wiper leak repair additional tips.
25th Jul 2014 7:01am |
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 |
Just to add to the above, you can also use a small flat blade to pry out the original seal then replace with the new one mentioned above. The plastic fitting then sits flush when you re-seat it... Sorry Stan just seen that you already did this L322 2007 TDV8 3.6 |
1st Mar 2021 8:40pm |
uzp315 Member Since: 19 Nov 2017 Posts: 428 |
Seeing photos of that motor brings back traumatic memories. |
3rd Mar 2021 6:53pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3067 |
I’ve just done this repair today.
8th Mar 2021 12:36am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6719 |
Glad it helped David Got - 2017 SDV8 Autobiography in Loire Blue
8th Mar 2021 7:47am |
I hate to play the ghoul, but if your experience is anything like mine, other failures are looming in the near future. When you get to the end of being able to repair the unit, you can make a new working one from a brand new replacement (incompatible with pre-facelift) motor and your old one:
8th Mar 2021 9:50am |
I caught mine early enough that it was just a dribble leaking and there was barely any crap inside the motor.
8th Mar 2021 4:45pm |
I too felt the warm glow of success when I too had swapped an o ring.
8th Mar 2021 5:29pm |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 523 |
I need to get the 10x16x4 Radial Oil Seal mentioned above, but link is now out of date.
31st Aug 2022 3:00pm |
I fitted this one to my car in Feb 2021 and haven't had any issues with it since.
31st Aug 2022 3:12pm |
Might be worth ordering this as well just incase you find any wear inside the motor when you open it up:
31st Aug 2022 3:14pm |
Amazing-thank you.
31st Aug 2022 3:19pm |
Hopefully i wont need that. I have taken it all apart and there was minimal rust, which i cleaned off and the gear looks perfect. I have put it back together temporarily while I await the seal, and its wiping well |
31st Aug 2022 7:04pm |
