![]() | Home > Technical (L405) > Range Rover spec |
jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 ![]() |
Guys how can I know if my car has laser head lights ? Range Rover are notoriously unhelpful. |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 784 ![]() ![]() |
I think you select laser in the headlight menu (like you do adaptive beam) so that’s the easiest way. Visually the only way to tell is look inside the square section of the DRLs (inside corner). The first picture has the laser lights and more going on in that section, the second has standard Pixel lights.
Thanks guys. I love you both:)
So....do you have the laser lights? |
Sadly no... |
I wouldn’t worry too much, the Pixel LEDs are very good and with how must the roads are you wouldn’t get a huge benefit from laser lights unless you live out in the country. I had laser lights on my last car (7 series) and the range was amazing, but I don’t miss them. MY23 Panamera E-Hybrid
