Home > Technical (L322) > Reduced performance |
Sleepy Jen Member Since: 15 Feb 2021 Location: Basingstoke Posts: 32 |
I have had issues with the U0415 codes on other vehicles (BMW/VW & Audi); 9 times out of ten it was to do with wiring or connectors for the ABS/speed sensors, or the sensor its self. In two cases the plate in the wheel bearing that the ABS sensor reads was at fault - new bearing/hub assembly required.
5th Mar 2021 10:07pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3543 |
these look like typical codes that come up from time to time but don't look like restricted performance codes.
6th Mar 2021 8:31am |
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 299 |
That’s great thanks sleeply Jen |
6th Mar 2021 8:32am |
I’ll check that out and display cheers GGDR |
6th Mar 2021 8:34am |
Just done a battery check 12.2 but it did flash across to 12 then held steady at 12.2 |
6th Mar 2021 9:12am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
I'd go with Greg.
6th Mar 2021 1:33pm |
Can you please excuse my ignorance what is the yellow or red RP FAULT please |
6th Mar 2021 7:01pm |
I'll stand to be corrected, but a red can come up if the DPF is blocked and it says vsit dealer, power is reduced and it's a slow acceleration to about 50ish. ISTR it may raise its head if you have a leak on the air inlet sides.
6th Mar 2021 7:17pm |
Cheers Richard |
7th Mar 2021 9:20am |
You're welcome S.
7th Mar 2021 11:11am |
Ok I had a play with the abs loom and the restricted light went out, only to come back on later. I seem to get 10 miles out of her before she throws her teddy bear 🧸 out of the pram. I have to say before I bought her I had the forsite to getting an IID unit which is already paying for its self. |
7th Mar 2021 9:55pm |
Sounds as if you are on the way. As we have the same model I'll follow this with interest. I'm bound to get the same fault sooner or later. Cheers
8th Mar 2021 10:57am |
Quick update it’s been fine for those last couple of days so fingers crossed 🤞also I got the dpf cleaned it did a auto regenerate and this afternoon I floored it and the amount of blue smoke out the rear was embarrassing but it seams to have cleared |
16th Mar 2021 10:49pm |
