Home > Maintenance & Mods (L322) > Tailgate rust prevention |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 |
I did my 2010 when the tailgate got replaced in 2014 after someone damaged it still rust free si it’s deffo worth the effort |
6th Mar 2021 10:06am |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
I did the same job last weekend and used Lanoguard 👍
6th Mar 2021 12:28pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
following just noticed bubbles on mine!! 2012 Vogue 4.4 TDV8 - Current
6th Mar 2021 2:29pm |
Maccaa Member Since: 03 Feb 2020 Location: Bristol Posts: 38 |
Jim, I believe Lanoguard is colourless/opaque ?, may I ask does it smell and which kit did you buy to do the tailgate, did you use the 360 sprayer? Ta Maccaa Current FF Westminster 4.4 V8 |
10th Mar 2021 2:16pm |
I bought the 5L with a 360 probe sprayer.
10th Mar 2021 2:37pm |
Jim thanks Jim, just what I wanted to know. did you use the 360 in the tailgate too? Current FF Westminster 4.4 V8 |
10th Mar 2021 2:50pm |
Yes. As far up either side as I could and all along the bottom.
10th Mar 2021 2:59pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
Having done a tailgate replacement this week, I'm currently choking on the fumes of the waxoyl that has now drowned the replacements interior |
10th Mar 2021 6:49pm |
jjfang Member Since: 13 Nov 2020 Location: Chicago Posts: 44 |
Lanoguard is similar to what Fluid Film/Wool Wax here in the US. Thats currently what im using, but my issue is that it drips none stop in the summer since it stays "fluid". I have a donor rust free tailgate from another Rover that was also painted the Santorini Black like mine (Super lucky). Im debating if I want to keep my tailgate on until mine rust through or just replace it and spray a different rust inhibitor since its rust free so I won't get the drippage from the stuff I spray |
18th Apr 2021 4:44pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4300 |
It will pass....I used Dynax on my top tailgate and it stank for a few days... I sprayed it through the drain holes and rammed my probe in to the max Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
18th Apr 2021 5:20pm |
Would this be something you would touch up maybe annually? They say its a waxy/soft finish that can self heal, are you able to confirm if this is really the case? I found two articles that say interesting test results. Im deciding between Dynax S50 or Noxudol 700 and the first link shows Noxudol finishing first and Dyanx in 5th but then in the second link in a test for Dynax it looks like Dynax did really well but Noxudol not as well. Curious to get peoples thoughts! https://www.auson.se/wp-content/uploads/20...y_uk_1.pdf http://www.bilthamber.com/media/downloads/PG-BH13-001.pdf |
19th Apr 2021 2:45am |
