Home > Maintenance & Mods (L322) > Front to rear break pipes |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16288 |
What are you going to ask your to do sir? Replace like for like? Or make replacements in copper?
4th Mar 2021 4:11pm |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 602 |
had mine done last year in copper think it was about £250 all in plus mot |
4th Mar 2021 6:35pm |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 427 |
4 hours labour at most for a decent garage to tackle this (probably less if they've done it before) + £10's worth of Cunifer pipe. If rear flexi's are replaced at the same time, then another £40 at best (if they use non genuine), so all up I'd be happy to pay an indy around £300 for this job.
4th Mar 2021 8:32pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 |
Pretty sure I paid £280 ish in January. Mine had actually split though, so pedal went soft. Went down further which stuffed the seals in the master cylinder. Needed a new one of those, so total Bill about £669.
4th Mar 2021 8:54pm |
Ianb4310 Member Since: 21 Sep 2017 Location: Gainsborough Posts: 201 |
Thanks everyone I’ve been quoted £220 plus the vat so happy with that by OFG Lincoln |
4th Mar 2021 9:14pm |
Sounds like a great price. It'd be worth them doing the rear flexi hoses (which are part flexi and part steel which corrodes) at the same time if they arent already.
4th Mar 2021 9:45pm |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 287 |
If you intend to keep the car, I would replace the flexis with braided stainless steel ones. Will last forever then. Did this on my D3 when I replaced the brakes all round (discs, pads and callipers)
5th Mar 2021 8:40am |
I’m going let OFG check it out and see what they recommend then let them go for it !!
5th Mar 2021 7:14pm |
