![]() | Home > Technical (L322) > Problems Starting... |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Hmmmm..... I wonder if it could be the in line fuel pump on its last legs?
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 ![]() ![]() ![]() |
Is that the main fuel pump in the engine bay or the narrow long one next to the tank? |
It’s situated under the car in the vicinity of the rear near side passenger seat. There is a plastic cover held closed by 2 10mm bolts.
How did you get on Mike?
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 ![]() ![]() |
As Jim's suggested, the lift pump (Primary pump) may well be on its way out. As the name suggests, the lift pump sucks the fuel out of the tank and delivers it to the high pressure pump. If the lift pump fails the high pressure pump has to do all the sucking as well as pressurising the fuel and delivering it to the injectors. Can take a lot of cranking to overcome this.
Thanks for the advice. I'm finally going to try to pull the fuel pump out.
