Home > Technical (L322) > Problems Starting... |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
Hmmmm..... I wonder if it could be the in line fuel pump on its last legs?
3rd Mar 2021 4:39pm |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 |
Is that the main fuel pump in the engine bay or the narrow long one next to the tank? |
3rd Mar 2021 7:17pm |
It’s situated under the car in the vicinity of the rear near side passenger seat. There is a plastic cover held closed by 2 10mm bolts.
3rd Mar 2021 7:43pm |
How did you get on Mike?
9th Mar 2021 9:59am |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 |
As Jim's suggested, the lift pump (Primary pump) may well be on its way out. As the name suggests, the lift pump sucks the fuel out of the tank and delivers it to the high pressure pump. If the lift pump fails the high pressure pump has to do all the sucking as well as pressurising the fuel and delivering it to the injectors. Can take a lot of cranking to overcome this.
9th Mar 2021 10:19am |
Thanks for the advice. I'm finally going to try to pull the fuel pump out.
31st Mar 2021 11:57am |
