![]() | Home > Maintenance & Mods (L322) > Rear bumper bracket rivets - cause of rear wing rust? |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 890 ![]() ![]() ![]() |
I think that’s an aluminium pop rivet, would need drilling out to remove. |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Hmmmm..... these are situated directly under where rust bubbles start to develop on the rear wings and I think that they allow moisture to enter the twin skin.
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233 ![]() ![]() |
Tri-Fold Bulbex Soft Fold Split Blind Rivet. Often used in fitting softer materials to a metal backing. LR part number is KYQ100010. Good luck with the repair. |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1544 ![]() ![]() |
Thanks for that info. I've never seen such a rivet before.
Thanks for your help guys 👍
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8374 ![]() ![]() ![]() |
The rusting is because it is where two panels come together and are spot welded on the inner return of the wheel arch, it doesn't matter how much rustproofing they try to put on during manufacture, it will be burnt off as it is welded and it will rust... The seam rusts through the outer panel, there will be far more rust inside...
