Home > Maintenance & Mods (L322) > Rear bumper bracket rivets - cause of rear wing rust?
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Hi all
I have changed the title of this post as I think that my search for what appeared to be a strange headed screw has identified a potential cause of rust bubbling, from the inside out, on the L322. I have left the rest of the post but the last photo shows where the problem may lie.
The plastic bracket that holds the rear bumper against the rear wing is held on by some sort of special screw. Can anyone tell me what type of screw head it is?
Jim
Post #585780 1st Mar 2021 10:28am
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I think that’s an aluminium pop rivet, would need drilling out to remove.
Post #585783 1st Mar 2021 10:39am
jim4244
Hmmmm..... these are situated directly under where rust bubbles start to develop on the rear wings and I think that they allow moisture to enter the twin skin.
I must admit that I have never seen a rivet like this before?
Jim
Post #585786 1st Mar 2021 11:43am
Classic888
Tri-Fold Bulbex Soft Fold Split Blind Rivet. Often used in fitting softer materials to a metal backing. LR part number is KYQ100010. Good luck with the repair.
Post #585830 1st Mar 2021 4:38pm
p38arover
Australia
Thanks for that info. I've never seen such a rivet before.
https://www.rivetsonline.com/blind-rivets/...d-rivets#1 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #585928 2nd Mar 2021 12:27pm
jim4244
Thanks for your help guys 👍
I think that these rivets are responsible for the rust that affects the rear wings of the L322. It would appear that water finds its way either along or through the rivet and into the space between the skins. The skin then rusts from the inside out.
Here’s a photo showing the location of the rivets in relation to some rust bubbling on my car.
As you can see the rust bubbling is in the area of the rivet on the left. It may well be worth removing your rear bumpers and sealing around the rivets and the plastic bracket to stop any potential water ingress.
Jim
Post #585931 2nd Mar 2021 1:27pm
The rusting is because it is where two panels come together and are spot welded on the inner return of the wheel arch, it doesn't matter how much rustproofing they try to put on during manufacture, it will be burnt off as it is welded and it will rust... The seam rusts through the outer panel, there will be far more rust inside...
"modern" cars have this panel join glued with the new panel adhesive that was not available back in 2000 when they designed the 322... This means there is no weld and the panel coating remains in tact preventing such a rust spot.
The back of the wheel arch is where any water collects that gets into the rear side cubby hole from the "built in" leak most 322's have
Getting into the boot sides and flooding the area with rust treatment where the two panels join will help stem rust but yours has gone too far for that, you need the rust cutting out back to clean metal which will require the return lip to be replaced, both skins... Then rustproof after it is fixed.
The rivets will have little effect on the rust there... Thumbs Up Pete
Post #585933 2nd Mar 2021 1:43pm
