Home > Technical (L322) > Drivers door won't latch
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Hi all,
So the kids were using the car in a game of hide n' seek yesterday. Subsequently I noticed that the drivers door won't latch shut, just bounces open.
There also seems to be not the usual resistance or tension on either the interior or exterior handles.
Does this sound like a cable has snapped, or more likely the latch?
Thanks! 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #585810 1st Mar 2021 1:39pm
Always
Might sound daft, but have you checked the seatbelt isn't blocking the door? (That's my favourite trick!)
Second daft suggestion - have you made sure the latch is 'open'?
And my third suggestion... have you messed around with the door catch mechanism (on the door) with a screwdriver pretending to be the latch bar... you can use the screwdriver to trigger the latch, handle to open the latch. It might be a little seized and need lubricating / manipulating so it springs into the closed position fast enough to grab the bar.
Post #585834 1st Mar 2021 4:55pm
The RR Bandit
United Kingdom 2011 Range Rover Vogue TDV8 Zambezi Silver
I've had this a few times especially on cold morning when the latch frozes open. I just hold the door fully shut and lock the door with the key. That will force the lock shut, then when you unlock the car the door will be snecked shut.
If that fixes it it's worth spraying the latch with WD40 or whatever to displace any moisture in the latch and keep it lubricated on cold mornings.
Hope that is of some help Thumbs Up 2011 RR Vogue 4.4 TDV8
Post #585836 1st Mar 2021 5:26pm
SidewaysMatt
False alarm a bit of a wiggle and jiggle when I didn't have 4 kids round my ankles and all good again! 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #586228 4th Mar 2021 1:44pm
