Home > Maintenance & Mods (L322) > Temp Sensors no reading
Sonearly
Plugged in IID to monitor settings and for both Temp and Voltages are coming up as 0. The DPF fill is also showing 32.1. Any ideas why zero readings and subsequently DPF now showing 32.1. The car also seems to have lost some economy, from average 35 mpg on run to around 33 mpg. It there anything I should be testing first, can you test the pressure sensors anywhere. Advice greatly appreciated. If the sensors have failed would it show incorrect DPF values.
Post #585669 28th Feb 2021 2:17pm
Sonearly
Car does seem a bit hesitant until warmed up also
Post #585670 28th Feb 2021 2:18pm
GGDR
32g normally means the DPF is blocked and also normally means you'll be in restricted performance....
. Cheers, Greg
Post #585671 28th Feb 2021 2:22pm
Sonearly
I have no faults and no warnings, main concern is why no readings from temp sensors. Driven 500 miles over the last couple of days.
Post #585700 28th Feb 2021 6:08pm
GGDR
How long have you had the car?
Wondering if the EGR or DPF has been mapped out?
You could try a battery reset (see wiki).
But if no warnings, then nothing to worry about?
. Cheers, Greg
Post #585710 28th Feb 2021 6:55pm
Sonearly
Had the car around 6 months, I’m pretty sure it has done a couple of regenerations as panicked when fuel consumption dropped to around 20 mpg after being on a motorway for 10 mins, was low for around 15 mins. Do you know how to tell if remap has been done, had the battery out a couple of months ago and did reset. Still not sure why temp sensors not reading of IID.
Post #585714 28th Feb 2021 7:06pm
kevinp
When you say you are sure it's done a couple of regens did it not have a warning light on the dash to tell you? I've had my car for over a year now and have never seen a warning light. My wife's jeep is always popping the warning light on.
Post #585750 1st Mar 2021 4:58am
Sonearly
No warning lights. I just did what it should do, it shouldn’t get to warning light to do regeneration.
Post #585755 1st Mar 2021 7:29am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
What sensors are you measuring for voltage in live values on the IID? Ideally go for Particulate filter differential pressure sensor - Bank 1 and see what the voltage is reading as well as the Oil quality fuel dilution factor (this needs to be below 7) as that will give us a starting point 2011 TDV8 Vogue SE
Post #585760 1st Mar 2021 8:03am
Sonearly
Brilliant thanks, will try later. As a precaution will be replacing hoses for silicone ones on the donut as I see one has been replaced previously. I can see a temp sensor has been changed recently on the service history, but unfortunately does not show part number.
Post #585762 1st Mar 2021 8:22am
dennij
The donut definitely needs the hoses upgrading to silicon, any leak on the induction side causes havoc with the DPF (trust me on this as I'm still having issues with mine) There are a number of posts on here where people have purchased a length of silicon hose and cut to length as it works out far cheaper 2011 TDV8 Vogue SE
Post #585766 1st Mar 2021 8:26am
Sonearly
Hi. Have taken the reading as per photo
Both reading 0
Post #586032 3rd Mar 2021 12:23pm
dennij
Have you connected the IID Tool to your PC/Laptop lately to check the firmware is up to date. I seem to recall that someone else had an issue with readings so decided to re-flash the software/firmware on the IID to resolve this. 2011 TDV8 Vogue SE
Post #586043 3rd Mar 2021 1:42pm
Sonearly
_5C86C8FB-941C-40B1-8AF2-5D9819679D04.png[/img]
Hi
Have reloaded firmware to IID. Still reading the same. Not sure what steps to take. Any advice greatly appreciated.
Post #586305 4th Mar 2021 8:48pm
dennij
Can you get any readings at all from the options within Live Values? Ideally if you have a member nearby who could plug their IID tool in it might help determine if it's a fault with the IID or a fault with the ECM not showing readings. 2011 TDV8 Vogue SE
Post #586339 5th Mar 2021 7:34am
