Home > Technical (L322) > Max Air Con button not working? |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1177 |
Not sure if this will help, as I don't know which model you have, if it's an L322, it doesn't sound like a fuse problem as the whole system works through a PCB buried inside the climate control panel unit, so sounds like a switch failure or a problem with the PCB. Used climate control panel units look like costing from £35 at the cheapest, it's quite a simple job to exchange units if you are handy with the tools.
27th Feb 2021 11:45pm |
Fish13 Member Since: 13 May 2009 Location: Aberdeenshire Posts: 21 |
Hi Rob,
28th Feb 2021 8:00am |
Hi Fish
28th Feb 2021 2:03pm |
Awesome buddy, cheers!!
28th Feb 2021 6:07pm |
