Home > Technical (L322) > fuel tank removal
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
forgot to mention in my last post
getting ready to do the job, i went to rover for the filter and seal ring
i got the seal ring but they said there is no filter
i will see IF i get it out RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #584663 21st Feb 2021 6:36am
That's because they are not listed where they usually list fuel filters on their system...
It's LR043154
https://lrbritishparts.com/?product=genuin...54-new-oem Pete
Post #584668 21st Feb 2021 8:58am
knares
the job is done
a just wrot what about it and it wont post RR 2005 4.4 petrol
Post #585050 24th Feb 2021 11:47am
knares
the job is done, no leaks
after soaking the fuel pipe connectors and blowing them with compressed air for several days my son managed to pull them off the pump fittings
the plan was to lift the pump up just enough to get the old seal out and put the new seal in and put it back together.
i lifted the pump up but i couldn't feel the seal
i lifted the pump up further and found the seal inside the tank, down around the pump
it had never had a seal since the last technician had the pump out.
its now all together no leaks.
having seen the fittings off and been able to see how they work, i am thinking of making a tool to remove them.
i looked on YouTube and squeezing them or using plyers is not on, for me.
not saying it hasn't worked RR 2005 4.4 petrol
Post #585057 24th Feb 2021 1:01pm
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
There are loads of videos on YT about this, I've been watching a few as I think my pump might need replacing. By far, this is the best, the guy explains it well, has great footage and even shows inside the tank how it all fits together. Worth a watch if you're trying this job
 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #585060 24th Feb 2021 1:10pm
That one is the diesel, the petrol is totally different, the pump is half that size and lives inside the tank about a foot forward from the access hole, the access hole is where the filter resides, the pump has a remote pickup and level in the other side of the tank and is joined to the pump with wiring and fuel hose... Thumbs Up Pete
Post #585075 24th Feb 2021 3:01pm
Tugger
Take it you didn't actually watch the video then Laughing
Clearly a petrol 2004 4.4L and he most definitley shows the remote pickup on the other side, made a huge point of it in fact. 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Fiat 500 1.2
Post #585080 24th Feb 2021 3:33pm
To be fare I didn't watch it all, just looks so different to mine, mind you it'll be the same as the OP's so I'll go and boil my head...!!! Thumbs Up Pete
Post #585109 24th Feb 2021 6:30pm
knares
yes that is the same as mine but the important part for me is getting the pipes disconnected which is not very clear.
he seems to be prying it off with a little screwdriver, which worked RR 2005 4.4 petrol
Post #585139 25th Feb 2021 2:57am
p38arover
Australia
In that video, that engine is not the same as my 2003/4 4.4 M62. I've replaced the alternator on mine and it sits inside the timing case and is water cooled. I have no idea what engine is in that one. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #585142 25th Feb 2021 6:01am
knares
i noticed that to but the tank part of the vid is the same, i think that is a different car RR 2005 4.4 petrol
Post #585174 25th Feb 2021 11:31am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
on mine it was nothing to do with the sender itself but the connector, we cut the connector out on both sides and soldered / sealed the wires together and hey presto working fuel gauge. that was from an article on here i got that tip. total cost of the repair was time and a few pence on connectors. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #585183 25th Feb 2021 12:22pm
