Home > Technical (L322) > fuel tank removal |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
That's because they are not listed where they usually list fuel filters on their system...
21st Feb 2021 8:58am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 739 |
the job is done
24th Feb 2021 11:47am |
the job is done, no leaks
24th Feb 2021 1:01pm |
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 |
There are loads of videos on YT about this, I've been watching a few as I think my pump might need replacing. By far, this is the best, the guy explains it well, has great footage and even shows inside the tank how it all fits together. Worth a watch if you're trying this job
24th Feb 2021 1:10pm |
That one is the diesel, the petrol is totally different, the pump is half that size and lives inside the tank about a foot forward from the access hole, the access hole is where the filter resides, the pump has a remote pickup and level in the other side of the tank and is joined to the pump with wiring and fuel hose... Pete
24th Feb 2021 3:01pm |
Take it you didn't actually watch the video then
24th Feb 2021 3:33pm |
To be fare I didn't watch it all, just looks so different to mine, mind you it'll be the same as the OP's so I'll go and boil my head...!!! Pete
24th Feb 2021 6:30pm |
yes that is the same as mine but the important part for me is getting the pipes disconnected which is not very clear.
25th Feb 2021 2:57am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1526 |
In that video, that engine is not the same as my 2003/4 4.4 M62. I've replaced the alternator on mine and it sits inside the timing case and is water cooled. I have no idea what engine is in that one. Ron B. VK2OTC
25th Feb 2021 6:01am |
i noticed that to but the tank part of the vid is the same, i think that is a different car RR 2005 4.4 petrol
25th Feb 2021 11:31am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
on mine it was nothing to do with the sender itself but the connector, we cut the connector out on both sides and soldered / sealed the wires together and hey presto working fuel gauge. that was from an article on here i got that tip. total cost of the repair was time and a few pence on connectors. 2012 Vogue 4.4 TDV8 - Current
25th Feb 2021 12:22pm |
