Home > Technical (L405) > Air suspension L405
Watty
Scotland 2017 Range Rover Autobiography SDV8 Santorini Black
Air suspension L405
Help please
when i stop and select access height the vehicle starts lowering then midway down i see it changes to select extended height. Now it now tells me suspension fault and switches of the control for height and terrain response there is no fault code logged.
any ideas please
2013 Autobiography 4.4 07 Vogue SE Java Black 3.6 TDV8
Black Leather heated/ cooled seats
Piano black trim deployable side steps
L405 Autiobiography 2017
Santorini Black with black pack
13 L405 4.4 Autobiography
Post #584737 21st Feb 2021 6:50pm
GraemeS
If the front struts are original then oil is likely to have leaked from the shocks into the air-springs which prevents lowering to access height. Going into extended height while trying to lower to access height is a typical indicator of the fault.
MY13 and MY14 L405 and MY14 L494 are affected.
Post #584771 21st Feb 2021 10:16pm
Watty
Re: Air suspension L405
Problem now sorted it was the exhaust valve at the compressor which was blocked, same problem as on the L322 a small hole drilled through the valve solved the problem 07 Vogue SE Java Black 3.6 TDV8
Post #584955 23rd Feb 2021 2:58pm
